Frame: Felt Custom Butted Super-light 7005 Aluminum, Forged Dropouts w/ Stainless Steel Inserts Fork:
Felt TKR carbon fiber
Components: Felt 3pc Cold Forged Track w/ CNC Machined Alloy 144mm B.C.D. 48t 3/32” Chainring x 15t 3/32” cog w/ lockring; Felt TkR Track Bar & Post
Wheelset: Felt TkR4 High Flange track hubs/Stainless Steel Spokes/30mm deep aero track rims, 28H front, 28H rear
Finish: Gloss Black
Sizes: 700c x 52, 54, 56, 58, 60cm
Weight: 17.97 lbs/8.17kg
COLOR:
Gloss Black & Red
SIZES:
Est. WEIGHT:
17.97lbs/8.17kg
FRAME:
Track Specific Custom Butted Super-light 7005 tig pulse welded Aluminum tubes, Aero 60mm Deep Seat Tube with rear wheel recess & Semi Aero Downtube, bladed aero seatstays with horizontal CNC dropouts with stainless steel inserts
FORK:
Felt Track Specific Carbon Fiber with 1 1/8" Steerer and oversized carbon fiber fork blades, 25mm offset with drilled crown for front brake
HEADSET:
Cane Creek type 1 1/8" Integrated with 20mm Cone and 2 X 7.5mm Spacer Stack
STEM:
FELT 1.2 6061 Alumnim 3D Forged Ø31.8mm with 7° Rise, 52cm=90mm, 54cm=100mm, 56-58cm=110mm, 60cm=120mm.
HANDLEBAR:
FELT TkR 6061 Aluminum with TRACK Drop, Ø31.8mm, 52cm=40cm, 54cm-58cm=42cm, 60cm=44cm
GRIPS:
Felt Gel Ribbon Tape BLACK with FELT 3D Logo
END CAPS:
Bubble-Tech Felt Logo End Plugs
SHIFTERS:
n/a
FRONT DERAILLEUR:
n/a
REAR DERAILLEUR:
n/a
CRANKSET:
Felt Track Cold Forged Aluminum, Polished and BLACK Anodized with 144mm B.C.D. CNC Alloy Chainring, 48T x 3/32"; 52cm-54cm=165mm, 56cm=167.5mm, 58cm=170mm, 60cm=170mm
BB SET:
FSA 68mm w/ Forged Chromoly Square Taper 107mm Spindle
CHAIN:
KMC Z610X Track 3/32" width
FREEWHEEL:
Track 15T x 1/2" pitch x 3/32" width fixed sprocket with lockring
BRAKE LEVERS:
n/a
BRAKES:
n/a
CABLES & HOUSING:
n/a
SADDLE::
FELT 1.3 Road Saddle with Carbon Injected Base, Embossed Cover and Hollow Chrome Moly Rails
SEAT POST:
FELT TkR Forged 6061 Aluminum 1 piece Superlight 2 Bolt Design, Ø27.2mm, 300mm
SEAT POST CLAMP:
Ø31.8 6061-AL Forged Aluminum, Chrome Moly 5mm x 0.8mm Bolt, Stainless Steel Nut-Bar. 16 Grams
F/HUB:
Felt TkR-4 Hi-Flange 28H
R/HUB:
Felt TkR-4 Double-Threaded Fixed/Fixed Hi-Flange 28H
RIMS:
Felt TkR-4 700c 30mm Deep Aluminum Aero Track, 28H RADIALLY LACED Front/28H 3 cross Rear
TIRE:
Vittoria Zaffiro Slick Foldable 700c x 23c
SPOKES:
BLACK Stainless 14G
PEDALS:
n/a
EXTRAS:
n/a
Источник: http://www.feltracing.com/09-catalog...ck/09-tk3.aspx
