Спортивный велокомпьюте
09.08.2019 в 13:56 (788 Просмотров)
Тестирую прибор уже около месяца. Во-первых новости насчет Стравы:
Schedule update on Strava integration and Running Programs
Regretfully, after trying our best to have this update out on time for you guys, it turns out the Strava integration still needs some further development and is unfortunately postponed. Building an automated integration on a third party web interface turned out to require more harmonization in our back-end system and is taking longer than we expected.
The Strava integration will be available to your use just before the New Year’s fireworks.
Если коротко, интеграцию пока сделать не удалось, но к НГ обещают.
Затем, писал в поддержку письмо:
Just received my v650. I was a bit confused by the difference between v650 and v450. V650 with the new firmware cannot sync by bluetooth, has no tests and training load and recovery function. Do you plan to add that functionality to v650? Also I could not found front bike mount for my comp. When will that accessory be available?
Ответ: Max - There are many updates planned for the V650 that will include the training functionality you detailed. Check back with us periodically on the release of these new features
И Еще: Hi Max! V650 will get the mobile sync and the sessions will add to Training load and Recovery status features. The front bike mount quality was not in the level we expected it to be so it wasn't released for sale. We're looking into other possibilities and will keep you posted when we have news to share. Also about the V650 features. //jaana
Резюме: Планируется мобильная синхронизация (ВТ или WiFi?), тренировочные программы и программы восстановления. Должны быть Vo2 тесты, т.к. они уже есть на v450. Что с передним креплением - не понятно. Пока подожду, если не будет - напечатаю на 3d принтере.
Теперь о впечатлениях. Сразу скажу, Гармином не пользовался, около пяти лет проездил на Sigma Rox 9/9.1
Плюсы:
- отличный экран, быстрая работа
- в последенем обновлении добавлено урасление экранами с кнопки, что актуально при езде в полных перчатках и в дождь
- есть полноценный навигатор с трэком и картами
- полностью поддерживаются все виды ВТ - датчиков, начиная с ноунэйм пульсометров и датчиков скорость/каденс и заканчивая моделями Wahoo. Кстати, сразу скажу: заказал два датчика скорость/каденс с али-экспресс. Один еще идет. Второй пришел за 2 недели, но сразу начал подглюкивать и отваливаться ненадолго, в результате дает погрешность маршрута в минус 10%. Кончилось тем, что в слякоть он вырубился и я его снял нафик. Сейчас он ожил, буду дома на станке с ним крутить. Планирую заказать Wahoo Blue SC вместо него.
- есть возможность подключения 4 велосипедов и создания нескольких профилей катания с полной кастомизацией экрана. Т.е. есть road cycling, MTB, Other. Также есть Indoor Cycling для тренажера. Этим удобно прользоваться.
- традиционная для Polar удобная работа с пульсом по пяти зонам, есть результаты поездки, описание benefits, возможность "круиз-контроля" (работы в определенной зоне), калории, fat burn
- есть возможность экспорта в Страву после сессии. Проверял, все корректно экспортируется с трэком, участками и лучшим временем по участкам.
Минусы:
- большой (пока не привык еще). Мне кажется, более удобен формат v450/ garmin 520. Не испытывал его на МТБ. Как он будет вести вебя на пражках/дрыжках и спусках с дропами можно только догадываться.
- батарея 10 часов. Для меня это мало, т.к. езжу бреветные серии. Зато можно подзаряжать на ходу, что радует.
- много недоделок в софте. Точнее, потенциал аппарата реализован на 45 % где-то. Ждем доработок, они сейчас идут постоянно.
- как уже говорилось, нет переднего крепления. Это, друзья, очень стремно, учитывая, что у полар свой стандарт площадки
- не реализована беспроводная зарядка, увы
- мало функций по энергосбережению
- нет никаких аксессуаров. не нашел защитных пленок на экран, а колхозить не хочется, т.к. форма их достаточно сложная, с кнопкой внизу/в центре
Общие впечатления:
Брал на bike-discount. Мне показалось, что выгоднее брать пустой комп и отдельно датчик H7. В комплекте с v650 идет датчик с H6, который только ВТ, а H7 поддерживает все протоколы. Т.к. у меня еще поларовские часы FT80, это удобно, т.к. пульсометр h7 подсоединяется и к v650 и к FT80. Несмотря на минусы, впечатления положительные. Очень жду обновлений от Polar. Сейчас v650 достаточно дешево стОит, а перспективы развития есть.
Да, в Polar Flow я Maxim Kheyfets. Подключайтесь, вместе веселее
- Категории
- Без категории
