05.10.2018 в 10:32 (1082 Просмотров)
Байк куплен в августе 2015 года и до сих пор используется по назначению.
Frame Alpha Platinum Aluminium, E2 tapered head tube, internal derailleur and dropper post routing, 100mm threaded BB, low-direct front derailleur mount, 170mm Closed Convert dropouts
Fork Alpha Platinum Aluminium, 135mm spacing, IS brake mount, suspension corrected, заменена по отзывной компании на tapered
Front hub Bontrager alloy, 135x5
Rear hub Bontrager alloy, 170x12
Rims SUNringle Mulefut 80mm 32-hole w/cutouts
Tyres Bontrager Hodag, aramid bead, 26x3.8"
Shifters Shimano Deore, 10 speed
Front derailleur SRAM X0
Rear derailleur Shimano Deore XT, Shadow Plus
Crank Race Face Ride, 36/22
Cassette Shimano SLX, 10 speed
Chain KMC X10
Saddle Fizik Tundra 2
Seatpost Bontrager Alloy, 2-bolt clamp, 31.6mm, 8mm offset
Handlebar Nukeproof Warhead Flat Bars 760mm
Stem Token Arsenal 80mm
Headset FSA IS-2, E2, sealed cartridge bearing
Brakeset Avid DB 1 hydraulic disc
Grips Token LockOn
