28.09.2018 в 16:14 (1143 Просмотров)
Байк куплен в июле 2018 года, прошел небольшую кастомизацию (тормоза, роторы, педали, седло).
Используется по назначению.
Frame Reynolds 520 steel, 44mm head tube, 31.6 I.D. seat tube, internal dropper post routing, ISCG05, sliding 12x148mm dropouts, Formula thru-axle
Fork Rock Shox Recon RL 29/27.5+, Solo Air spring, external rebound, lockout adjust, 32mm stanchions, 15x110mm axle, tapered aluminum steerer, 120mm travel
Headset FSA Orbit, Alloy cups
Wheels WTB Scraper i40 TCS tubeless 27.5" rims, Formula sealed bearing 15x110mm front & 12x148mm rear 6-bolt disc hubs, stainless spokes
Tires Vittoria Bomboloni, 27.5 x 3.0”, TNT tubeless
Rear Derailleur Shimano SLX Shadow Plus, 11-speed
Shift levers Shimano SLX, 1x11-speed
Chain KMC X11-1, 11-speed
Cassette Shimano M7000, 11-speed, 11-46T
Crankset Shimano SLX
BB Set Shimano Hollowtech 2
Pedals Shimano m520
Brakeset Shimano Deore, 180mm front & 160mm rear, Reverse 6-bolt rotors
Handlebar Ritchey Trail, 760mm x 20mm rise
Stem Ritchey Trail, 60mm
Grips Jamis Lock-On
Seat Post Ritchey Trail Comp, 31.6 x 400mm
Saddle Nukeproof Neutron
Size 21”
Weight 14,5 kg
