Garmin Fenix 7 (Pro) / Epix 2 (Pro) - Страница 7
Страница 7 из 115 ПерваяПервая ... 25678912173757107 ... ПоследняяПоследняя
Показано с 61 по 70 из 1143
Тема: Garmin Fenix 7 (Pro) / Epix 2 (Pro)
  1. #61
    Alpha version 9.14
    • Added SatIQ support.
    • Added eBike support.
    • Added Race Day features.
    • Added Stocks widget glance.
    • Added a Reference Point app.
    • Added widget glance folders.
    • Added Cycling Ability feature.
    • Added Golf Virtual Caddie support.
    • Added categorization to Activity setup.
    • Added Training Readiness widget glance.
    • Added a power key control menu item for RCT.
    • Added Golf wind speed and direction support.
    • Added ability to disable temperature recording for an activity.
    • Added support for Run Power when paired with a compatible accessory.
    • Added multicolor support to Climb Pro graphs for non-biking activities.
    • Added a "What's New" screen to call out new features in software updates.
    • Added a watch face chart data fields for battery level and floors climbed.
    • Fixed issues with Jumpmaster wind entry.
    • Fixed issue with the Lock on Road feature.
    • Fixed some localization/translation issues.
    • Fixed issue with auto lap pace alert showing 0:00 time.
    • Fixed golf Tournament mode Green View zoom scaling issue.
    • Fixed issue with hours field for Set Timer in strength workouts.
    • Fixed issue with touch interaction when viewing a Climb preview.
    • Fixed inability to access Segments during an Ultra Run activity.
    • Fixed potential corrupted characters in Daily Suggested Workout.
    • Fixed potential screen flash when using a Connect IQ watch face.
    • Fixed potential shutdown when changing music during an activity.
    • Fixed issue with Climb Pro graph coloring for some bike profiles.
    • Fixed potential shutdown when receiving a tip while on a Connect IQ watch face.
    • Fixed issue causing device to incorrectly report that it was out of storage space.
    • Fixed potential shutdown when in a strength workout and transitioning from a jog step.
    • Fixed issue where a solar setting was showing up in the Garmin Connect app on non-solar devices.
    • Improved Wi-Fi download speeds.
    • Improved automatic altimeter calibration.
    • Improvements made to Daily Suggested Workouts.
    • Improved VO2 Max graph to now show 4 weeks of data.
    • Improvements and fixes made to Green Contours support.
    • Improvements and fixes made to the Adventure Race activity.
    • Improved Flashlight to remember configured settings over a power cycle.
    • Improved sensors menu by moving connected sensors to the top of the list.
    • Improved the automatic max heart rate notifications and associated settings.
    • Increased the maximum Golf Club count to 30.
    • Update usage of alpha/beta status on About page.
    • Updated phone app pairing flow to now use PIN comparison.
    Последний раз редактировалось pavlinux; 04.07.2022 в 14:22.
  2. #62
    Портировали с 955 что ли?
    Ну и бардак у них там.
  3. #63
    Alpha version 9.22
    1. Added a trophy to be displayed after completing a race.
    2. Added ability to adjust gear weight for cycling power guides.
    3. Added ability to reorder stocks in the stock widget.
    4. Added adjust terrain option to cycling power guides.
    5. Added confirmation page after completing a race.
    6. Added course directional arrows to course lines on the map.
    7. Added course elevation page to Primary Race widget.
    8. Added course map preview to Race Widget.
    9. Added Cycling Power Guide support.
    10. Added Effort page to cycling power guides.
    11. Added follow course and PacePro selection to the Primary Race widget.
    12. Added Heat Acclimation history page to Training Status.
    13. Added HRV Status to Training Readiness and Training Status.
    14. Added Load Focus access to Primary Running events.
    15. Added main page to HRV Status Widget.
    16. Added Move/Copy prompt for adding individual glances to a Glance folder.
    17. Added option to adjust rider position to Cycling Power Guides.
    18. Added option to copy Glances back to list if folder is deleted.
    19. Added options menu to Primary Race widget.
    20. Added Plan Overview page to Daily Suggested Workouts.
    21. Added Sleep Score history page to Sleep widget.
    22. Added support for custom race icons in the Primary Race and Race Calendar widgets.
    23. Added support for the 'Software Update Check via Wifi' to now be accesible via Garmin Connect Mobile.
    24. Added 'swipe to delete' support to the Stocks widget.
    25. Added text marquee to Primary Race widget.
    26. Added the ability to adjust power guide effort.
    27. Added the ability to view specific splits within a power guide.
    28. Fixed HRV Status highlighting incorrect unbalanced section in the widget glance.
    29. Fixed HRV Status when in a glance folder.
    30. Fixed inconsistent VO2 Max value between the widget glance and Training Status.
    31. Fixed incorrect Load item in Training Readiness.
    32. Fixed issue causing Connect IQ watch faces to be stuck in their high power mode after palm touching to get back to the watch face.
    33. Fixed issue causing excessive Daily Suggested Workout prompting.
    34. Fixed issue causing inconsistent sleep values in various widget glances after wakeup.
    35. Fixed issue causing missing Training Status and Race Predictions.
    36. Fixed issue causing potential empty glance folders.
    37. Fixed issue causing sluggishness in glances when Connect IQ glances were present.
    38. Fixed issue causing widget glance loop to not time out.
    39. Fixed issue where a Connect IQ watch face would be stuck in its high power display while watch was in low power mode.
    40. Fixed issue where a user could not advance past the daily suggested workout and into a running activity.
    41. Fixed issue where activity summary would not always timeout back to the watch face.
    42. Fixed issue where altitude acclimation would not return to the training status widget.
    43. Fixed issue where battery saver could enable unexpectedly.
    44. Fixed issue where Cycling Power Guides were not changing after edits were made.
    45. Fixed issue where HRV status might not appear in Garmin Connect correctly.
    46. Fixed issue where incorrect text could be displayed on the map download page.
    47. Fixed issue where incorrect training effect could be shown in the post activity summary.
    48. Fixed issue where power guide data fields would not properly update during an activity.
    49. Fixed issue where power save would activate even if navigation was still calculating.
    50. Fixed issue where RCT could disconnect while on the widget glance.
    51. Fixed issue where recovery time would show "hours" instead of "days."
    52. Fixed issue where some course points could not be selected.
    53. Fixed issue where the calendar widget would not update inside a widget glance folder.
    54. Fixed issue where the title of a widget glance folder would not always display.
    55. Fixed issue where turning on Night Vision altered Pulse Ox check mode settings (Tactix 7 only).
    56. Fixed issue where user could be prompted to select which wrist their watch is on after already configuring this setting.
    57. Fixed issue where users may need to click the start button twice to enter an activity.
    58. Fixed issue where watch would crash when syncing a new calendar race event.
    59. Fixed issue with automatic golf course updates.
    60. Fixed issue with cycling power guides where changes were not being saved.
    61. Fixed issue with incorrect page being pushed for the Training Readiness stress factor.
    62. Fixed issue with VO2 Max coloring in the Training Status widget.
    63. Fixed issue with weight while creating a cycling power guide.
    64. Fixed issue with widget glance folder creation when accessing via main menu.
    65. Fixed missing 'long ride' string in Daily Suggested Workouts.
    66. Fixed missing page indicators on Training Status and Training Readiness widgets.
    67. Fixed potential issue where sleep data was missing from the watch but still present in Garmin Connect.
    68. Fixed potential issues with Connect IQ app installs.
    69. Fixed potential shutdown after updating an HRM device.
    70. Fixed potential shutdown on the Sensors' About page.
    71. Fixed potential shutdown when viewing the race event before the start of a run activity.
    72. Fixed potential UI issue with Load Focus sub text in Training Status.
    73. Fixed potential UI issues with the Acute Load History graph in Training Status.
    74. Fixed sleep score history graph showing values in reverse order.
    75. Fixed sleep score history graph when less than 7 days of data.
    76. Fixed UI issue on Training Status tips page.
    77. Fixed Xero widget not acquiring GPS.
    78. Improve fonts on acute load page.
    79. Improve virtual caddie rounds remaining to have a black background instead of white.
    80. Improved alignment of sub-data in folder glance view.
    81. Improved automatic altimeter calibration.
    82. Improved Load Focus glance indication to make it dynamic.
    83. Improved race time predictions.
    84. Improved UI for Primary Race widget.
    85. Improved/Fixed stocks app data.
    86. Improved/Fixed Training Status and Training Readiness.
    87. Updated cycling power guide UI for pair power meter prompt.
    88. WHR improvements.
    ---------- Добавлено 29.07.2022 в 19:13 ---------- Предыдущее сообщение 25.07.2022 было в 23:20 ----------
    Ещё прилетело
    Beta Version 9.24
    1. Added elevation graph to cycling Power Guide preview.
    2. Added 'End Sleep' prompt to App list access.
    3. Added map option to Cycling Power Guide option menu.
    4. Added Race Day PacePro confirmation page.
    5. Added trophy for completed Primary Race events.
    6. Fixed "No race" text in Primary Race widget glance.
    7. Fixed 'As Of' timestamp for Stocks for closing price.
    8. Fixed daily Floors Climbed goal not alerting.
    9. Fixed inconsistency with HRV Status glance view and widget view.
    10. Fixed incorrect software version number showing up on wifi software download page.
    11. Fixed issue where "sync failed" would show up on the watch after checking for updates via wifi.
    12. Fixed issue where VO2 Max could be missing from Training Status while paused.
    13. Fixed issue with ephemeris download via Wi-Fi.
    14. Fixed potential issues causing increased battery drain while an InReach device is paired.
    15. Fixed potential shutdown when canceling a map manager map download.
    16. Fixed potential shutdown, while powering down the unit, due to a Wi-Fi sync still in progress.
    17. Fixed UI issues with Cycling Power Guide data page.
    18. Increased '7D AVG HRV' widget string size.
    19. Removed prompt for Cycling Power Guide course navigation as course navigation is required.
    20. Updated Training Readiness onboarding page.
    ---------- Добавлено в 19:22 ---------- Предыдущее сообщение было в 19:13 ----------
    В общем добавили 32 функции, наверно самая интересная это Cycling Power Guide из Edge 1040
    Перед стартом выбираете Power Guide, там выбираете дистанцию, по которой будете тренироваться/напрягаться,
    далее нужно ввести вес снаряжения с велосипедом (gear weight).
    Там же добавить или оставить (0% от FTP) усилие (Effort), по которому будет произведен расчёт планирования нагрузки.
    И в последней бете добавили Просмотр Графика высот (elevation graph preview)
    А, ещё конечно же HRV Status
    Последний раз редактировалось pavlinux; 11.09.2022 в 13:56.
  4. #64
    Китайский браслетик ... $19.10 https://aliexpress.ru/item/1005003389829135.html
    Почти полная копия Vented Titanium Bracelet with Carbon Gray DLC Coating,
    конечно там не титан и не DLC, но и не стоит $300.00 USD
    И кстати, оригинальный нифига не чёрный, скорее этом можно назвать "тёмно-тёмно серый", "мокрый асфальт", ...
    Поэтому он с черными часами х...во смотрится, примерял в прошлом году к Tactix Delta.
    Оригинальный, 300$ вообще не стоит, ни по дизайну, ни по конструкции.
    Последний раз редактировалось pavlinux; 30.08.2022 в 12:42.
  5. #65
    кожанный с подкладкой, самый любимый. металл тоже иногда ношу.
    https://www.amazon.de/gp/product/B09...?ie=UTF8&psc=1
  6. #66
    кожанный с
    Мой кожанный уже в говнище убитый
  7. #67
    А, ещё вот такой, нейлоновый на липучке, за 2$, прикупил https://aliexpress.ru/item/1005003512086200.html
    Смотрится конечно нищебродски, но для спорта и точных измерений самый лучший вариант
    При более плотной натяжке, чем силиконовым, его легче носить долго. Ну и весит почти ноль грамм.
    Последний раз редактировалось pavlinux; 30.08.2022 в 14:00.
  8. #68
    Это теперь можно смело назвать FENIX 7 Series
    Последний раз редактировалось pavlinux; 02.09.2022 в 18:52.
  9. #69
    Вопрос. Поля данных разделены тонкими линиями. Иногда та или иная линия становится толстой. Что это и напаркуа?
  10. #70
    Giant Contend AR 2 Rockrider st540
    Южное Подмосковье
    Кто-то уже пробовал 955. Есть смысл на них с 945 переходить?
  1. Продам Garmin Fenix 2
    от kdj1582 в разделе Свет и электричество
    Последнее сообщение: 04.04.2015, 08:22
  2. Продам Garmin Fenix
    от Dr. Boson в разделе Свет и электричество
    Последнее сообщение: 26.03.2015, 11:05
  3. Garmin Fenix 3 и Epix
    от ShaDoZ в разделе Электроника
    Последнее сообщение: 15.03.2015, 11:38
  4. Продам Garmin fenix
    от Пинцет в разделе Свет и электричество
    Последнее сообщение: 28.07.2014, 19:56
  5. Продам Часы Garmin Fenix 2 с HRM (с монитором сердечного ритма)
    от Xavier Teodonius в разделе Свет и электричество
    Последнее сообщение: 10.07.2014, 21:49
