Fixed: Strava Live Segments not showing consistently
Fixed: TSS/NP/IF displayed as "0" in ride summary
Fixed: Rerouting sounds and notifications while paused
Fixed: LEDs not matching correct HR zone
Fixed: Maps stuck in "Queued" state when downloading multiple maps
Fixed: Background workout recovery
Fixed: Maps page sometimes incorrectly reporting download failure
Fixed: Strava Live segments not syncing
Fixed: Issue with scaling current interval during planned workouts
Fixed: Max Speed data field displayed as AVG Speed when language is set to Chinese (вот китайцам счастья было)
Fixed: Crash on long rides
Fixed: Routes with Turn by Turn not displayed in ELEMNT app
Fixed: Map pack downloads getting stuck in queue
Fixed: Incorrect L/R Balance shown for some power meters
Fixed: Blank map tiles when no data fields are selected
Fixed: Incorrect Turn by Turn directions on Strava routes
Fixed: Nearby riders flickering on map page
Fixed: Auto-shutdown not working correctly
Fixed: Routing issues when the finish is near the start or when "Route to start" overlaps the route
FIXED: Climbing profile incorrectly displaying on map page
FIXED: Incorrect power values being displayed from SRM power meters
FIXED: Target BPM data field showing as BPM % when using Training Peaks workouts
FIXED: Power from Rotor 2Inpower freezing when not pedaling
FIXED: incorrect default settings
FIXED: maps not displayed in certain areas
FIXED: various stability improvements
FIXED: Bug affecting Strava syncing when connected to WiFi
FIXED: Auto-calibration incorrectly appearing for select power meters when coasting
FIXED: SRM CTF power issue creating negative power values
FIXED: Config backup not working after factory reset
FIXED: Debug map management no longer displays for standard users
FIXED: Various crash fixes
FIXED: Bug causing momentary UI freezes.
FIXED: text capitalization on sensor discovery screen
FIXED: bug preventing display of left/right percent balance data for Pioneer Power Meters when set to Dual ANT+ mode
FIXED: bug preventing display of w/kg data for Pioneer Power Meters
FIXED: bug preventing display of Pioneer Power Meter mode change and magnet calibration functionality
FIXED: bug when transferring planned workouts
FIXED: bug preventing ANT+ FE-C connectivity with some third party trainers
FIXED: ELEMNT/BOLT automatically switching to Pioneer pedaling monitor mode
FIXED: Pioneer calibration exiting automatically after cancelling
FIXED: GPS drops after 3-4 hours
FIXED: Auto pause not working
FIXED: ANT+ sensors not reporting battery levels
FIXED: Riding Best Bike Split routes changing CLIMB gradient, but not KICKR resistance
FIXED: Incorrect target Watts in planned workouts
FIXED: Bug causing unexpected power off or reboot
FIXED: Duplicate uploads to sharing sites
FIXED: Issue with importing routes from specific third party apps
FIXED: Issue causing the 'Include Zeros in Avg Cadence' option failing to default to 'off' after factory reset
FIXED: issue causing ELEMNT crashes related to low memory
FIXED: issue causing ELEMNT not to recover rides after battery dies
FIXED: issue with Komoot route sync
FIXED: issue with Fitif Power meter not pairing
FIXED: issue causing Strava Live Segment page to not populate
FIXED: various other bug fixesFIXED: Shimano FC-R9100 power meter calibration failure
FIXED: Powertap P1's not registering crank length capability
FIXED: Grade data field displaying "- -" when climbing
FIXED: 3 second average power dropping to 0 <--
FIXED: Power data field dropping to 0 <-- КАК ПЛЯ, можно это прое....ть и не заметить?
FIXED: Favero Assioma average power and cadence incorrect
FIXED: PowerTap hub power meter data low
FIXED: Issue where user has to resync starred segments before each ride
FIXED: Current grade data could fluctuate on a steady climb
FIXED: bug with Garmin Vector power meter calibration
FIXED: bug causing issues with GPS accuracy during long rides (6+ hours)
FIXED: bug causing sensor disconnects and failure to recover sensor connection after disconnect
Fix issue where temperature data lost after a workout end
Only write the sensors that are used to the FIT file
Fix issue where planned interval repeating intervals are lumped together
Fix issue where Strava goal appears for the wrong segment
Data Field: when workout time >10hrs, don't show seconds
Fix planned workout 10sec notifications or very short intervals
Fix wheel circumference issue for Elite Direto
Fix issues when performing 2nd spindown in same power cycle
Fix incorrect duration on some planned workouts
Planned Workout interval graph not showing unless workout is paused
Planned Workouts - Graph doesn't scale as difficulty percentage is changed
Planned Workouts - Laps created incorrectly after pause
Planned Workouts - Interval notifications should appear on KICKR page during a Planned Workout
Add support for web4trainer share site
Fixed an issue where starting certain routes on KICKR would cause a 100% resistance command sent to KICKR
Fix issue where the ELEMNT would auto-switch to the lap page if the lap page was disabled in the companion app
Fix an issue where ELEMNT would forget your gear’s teeth-count configuration
Fixed an issue where a bad pressure sample could corrupt your elevation and grade data
Fixed an issue where a bad power sample could corrupt your power data
Fixed some issues transferring workouts to the companion app
Fix incorrect elevation data after mid workout shutdown and recovery
Fix issue where call/SMS/email notifications were hidden behind the workout paused notification
Fixes an approximately 20-second hang sometimes seen on ELEMNT startup
Fixed an issue causing some sensors to take a long time to connect after bootup
Fixed Komoot roundabout exit number
Fixed OFF Route notification only staying on for a short time
Improvements to RideWithGPS turn by turn parsing
Fixed distance to go not updating on route detail screen
Fixed issues with some RideWithGPS passwords
Fixed issue with distance not incrementing after workout recovery
Fixed Normalized Power, IF and TSS calculations
Fixed issue with some of the history detail being cut off
Fixed continuous beeps on some route turns. Beep once when the banner is shown and once again just before the turn.
Fixed layout of TurnByTurn banner on map page with no data fields
Fixed Ride Recovery from not recovering after reboot
- Fixed: Improved auto-upload logic for better performance
- Fixed: Wifi not turning off after uploads finished
- Fixed: Improved support for roundabouts in turn by turn.
- Fixed: Added confirmation before adding data fields when pairing new sensor
- Fixed: Duplicate power fields when using with KICKR
- Fixed issue with gaps in temperature data.
Fixed: Crash when viewing some history detail.
Fixed: issue uploading to third party sites.
Fixed: Mixed units was not changing height.
Fixed: Crash bug checking Wahoo Sensors for firmware upgrade.
Fixed: Crash when deleting workout on ELEMNT.
Fixed crash loop bug in workout recovery
Fixed bug that caused Recovering Workout to Display on start up
Fixed issue of deleted routes not clearing from ELEMNT
Fixed issue with sensor info in FIT file all having manufacturer set to Wahoo
Fixed menu selection not visible when backing out of menus
Fixed issue with P1 battery status showing incorrect labels
Fixed short (2-10sec) sensor and phone connection dropouts.
Fixed LED flicker
Ты точно Ваху купил? Не китайский проводной велоспидометр c Али за 10$. Только они работают как заявлено, все 25 мега функций. )))
