В хорошем состоянии.
Shimano XT 2x11 Front Derailleur FD-M8025 Direct Mount Down-Swing
Подробное описание :
Compatible with traditional mounting standards in 4 standards. The XT FD-M8025 shifts your 2x crankset with authority and precision.
Debuting on XTR M9000, the light and crisp shift action of the DEORE XT SIDE SWING front derailleur (FD-M8020 2x11 or FD-M8000 3x11 option) has been designed with long travel trail bikes in mind. Both M8000 derailleurs bring a drastic reduction in shift effort with efficient cable routing and enhanced stability, while also increasing tire clearance allowing for shorter chainstays. High clamp, low clamp, D-type and E-type mounting options are available. In addition, the 2x10 front derailleur FD-M8025 are available as well in a TOP SWING or downswing execution.
Dyna-Sys11
The real advantage of 11-speed is the ability to have all the range you require without sacrificing the rhythm you need.
Features
Super light shift action
2x mounting options: High clamp, Low clamp, D-type, E-type (without plate)
Designed with long travel trail bikes in mind
2x11-speed crank only
Product features
Use: MTB
Group: XT
Model: FD-M8025-D
Mounting: Direct Mount
Cable route type: Dual Pull
Gear front: 2-speed
Gear rear: 11-speed
Top gear teeth: 34-38T
Total capacity: 10T
Compatible Chain: HG-X 11-speed
Chain stay angle: 66-69°
Chain line: 48.8mm
Material
Aluminum
Steel
Weight
139g
Scope of delivery
Цена : 500. По вопросам в ЛС.
