Чтоб писать 72 часа, это должен быть часовой спринт на пульсе МПК.
Последний раз редактировалось pavlinux; 04.08.2020 в 23:13.
Вон чо кризис с разрабами делает
Fenix 6 Series - 10.75 Beta Releasehttps://forums.garmin.com/outdoor-re...5-beta-release
- Added support for Livetrack 2.0.
- Added support for Course Upload (w/ Livetrack 2.0)
- Added support for new even types with Live Event Sharing. (Multisport/Every Mile etc.)
- Added support for descriptive WiFi errors when syncing music. (Pro models only)
- Added support for configuring map settings during an Expedition activity.
- Added support for battery hours remaining as a data field option.
- Added support for displaying running and cycling VO2 Max for a multisport activity when applicable.
- Added support for automatically disabling battery saver once the device is above 80% charge.
- Brought in Bluetooth stability improvements.
- Brought in PacePro improvements.
- Brought in XCS improvements.
- Brought in sleep improvements.
- Fixed an issue where one would get a music provider notification after clearing device settings while powering on the device. (Pro models only)
- Fixed an issue where summary activities (sync’ed from another device) were showing up in the list of navigable activities.
- Improved the music provider switching experience. (Pro models only)
- Improved connected widget glances to indicate loss of connectivity by adding a red exclamation.
- Improved off wrist detection. (Requires 7.12 Sensor Hub)
- Made several user interface improvements for the altitude acclimation widget.
- Made several improvements to the music experience. (Pro models only)
- Made several bug fixes for golf.
---------- Добавлено 10.08.2020 в 19:14 ---------- Предыдущее сообщение 07.08.2020 было в 02:41 ----------
Там фигня такая, в бета прошивку разрабы запихали версию GPS: 4.50,
буквально через день этот же разраб рекомендовал откатится до версии 4.40 ...
Ну я долго не думая написал: Какая причина? Слишком хорошее обновление получилось?
Надо повёлся ... кто-то кипятком писает от качества трека на 4.50, кто-то нифига не понимает,...
4.40 как по мне так идеален https://www.gpsvisualizer.com/displa...02120-map.html
---------- Добавлено 12.08.2020 в 00:47 ---------- Предыдущее сообщение 10.08.2020 было в 19:14 ----------
Fenix 5S Plus (2019) vs Tactix Delta (2020)
Последний раз редактировалось pavlinux; 12.08.2020 в 01:04.
Кто знает сколько сейчас гарантия на forerunner? 735 залипли кнопкой вниз и при включении в вечном тест моде. Куплены в конце 2018 года на б-к. Б-к конечно написал, присылай, но как бы не вышло потом, что гарантия ек )
Второй вариант рассматриваю вскрыть экраны на али по 250р и поменять кнопку ) но если они на гарантии то канеш проще по гарантии.
Отпишусь и тут.
Итого, ответил гармин на второй запрос по ремонту сломанного датчика давления.
Теперь предложили замену за 200 баксов
чертовы клоуны...
Разумеется, пользоваться этим щедрым предложением я и не собирался... что было сделано - заказал на ибэе корпус 5х, его продают с датчиком, вибромотором и оптическим сенсором в сборе за 25 долларов.
Вчера он приехал, состояние почти нового, хз откуда китайцы берут эти корпуса, при желании можно попробовать пробить по серийнику, наверное.
Изначально план был пересадить датчик в родной корпус, чтобы сохранить серийный номер.
Так и было сделано, для этого сначала пришлось снять вибромотор
Что интересно, датчики немного отличаются:
слева старый, справа новый. Я не знаток техники, назначение медной херни на старом неясно.
Все шло отлично до того момента как я стал закручивать последний болт, крепящий экран к часам... вроде сильно не тянул, но башка свернулась, и часть болта осталась в отверстии корпуса выкрутить его никак не удалось...
Пришлось все разбирать заново, пересаживать назад в новый корпус, зато по итогу удалось снять заднюю пластину с серийным номером и переставить и ее - она крепится, как и писали на болтах и клее.
В общем, сейчас все работает как надо.
з.ы. китаец, гад, прислал корпус с оборванным шлейфом оптического датчика... так что вибромоторчик с датчиком взял из старого...
з.з.ы. что интересно, площадь дачтика у феникса раза в три меньше, чем у аналогичного у амбит 3. хз, влияет ли это на что-то...
Последний раз редактировалось Armand; 21.08.2020 в 10:30.
В Фениксы ANT+ FE-C впихали https://www.dcrainmaker.com/2020/08/...unner-945.html
---------- Добавлено 25.08.2020 в 03:09 ---------- Предыдущее сообщение 22.08.2020 было в 01:32 ----------
Fenix 6: Software Version 11.10 & Sensor Hub 7.12
- Added additional options to Live Event Sharing. Triggers added for Every Mile and Transitions (allowing for multi-sport use)
- Added support for displaying courses to viewers of user's LiveTrack sessions.
- Added support for FE-C and Smart Trainer control. See options in Bike Indoor activity.
- Added support for canceling a route when in simple tracking mode for Indoor Climb.
- Improved Bluetooth stability and reliability.
- Improved the music experience on device.
- Fixed an issue where smart notifications received in quick succession would not populate its options correctly.
- Fixed an issue where the device would fail to save an activity and the progress spinner would spin indefinitely.
- Fixed an issue with the user interface of the alarm page.
Sensor Hub 7.12 Change Log
- Improved off-wrist detection
---------- Добавлено в 03:24 ---------- Предыдущее сообщение было в 03:09 ----------
Апдейт хороший.
Качество GPS реально улучшилось. Вот только в режиме Ходьбы, да и любой низкоскоростной активности, рисуется как броуновское движение.
PulseOх вроде исправили, в последние недели 95-97% кажет.
Как уже написал DCR - FE-C без графика интервалов это ужасно не удобно. Пока особо желания нет даже потестировать.
Барометр с альтиметром (в режиме часов) как жили, так и живут своей жизнью.
Последний раз редактировалось pavlinux; 25.08.2020 в 03:25.
