Ох, продаю мощный НОВЫЙ зверь! (запечатан)
Frame
aluminium 6061, Gravity Casting Interface, hydroformed, thru-axle M12 (1.75) x 148mm, disc brake Post Mount, Travel: 120mm
Drive unit
Bosch Performance CX, 250W, 75Nm, 25km/h
Display
Bosch Intuvia
Battery
Bosch PowerPack, 500 Wh
Charger
Bosch quick charger 4A
Fork
FOX 34 Float Performance Lockout, air, Travel: 120mm, aluminium steerer tube 1 1/8" - 1 1/2" tapered, thru-axle Boost
Dämpfer
FOX Float DPS Performance EVOL, air
Shifting system
EX1, 8-speed, Sram
Schalthebel
Sram EX1, trigger switch
Rear sprocket
Sram XG899, 11-48 teeth
Chain
Sram EX1
Chain wheel
Haibike CNC sprocket black steel, plus, 16
Brake lever
Magura MT54 HC-lever, aluminium
Front brake
Magura MT5, aluminium, 203mm
Rear brake
Magura MT4, aluminium, 180mm
Tires
Schwalbe Nobby Nic Evo, 75-584
Rims
Rodi TR40, with eylets, aluminium
Front wheel hub
XLC Evo disc, thru axle 15x110 boost
Rear wheel hub
XLC Evo disc, thru axle 12x148 boost
Spokes
DT Swiss Industry, black
Handlebar
Haibike Components TheBar ++ 740mm
Grips
XLC lock on grips Sport
Stem
Haibike Components TheStem ++, A-Head, Bar bore: 31.8mm, 7˚
Head set
A-Head Alloy Tapered
Saddle
XDURO Light MTB
Seat post
XLC AllMtn, Remote, telescope, 31.6mm
Pedals
XLC Freeride, Plattform Pedal
Цена 3500 Евро
