В двух словах, какая разница между Hardrock Sport и Hardrock XC Sport?
80% езды будет по городу, 10% лес, 10% горы, хотя город у нас тоже чем-то лес с горами напоминает
Цена обоих одинакова.
Намного ли хуже Hardrock XC?
Заранее спасибо
Hardrock Sport
FRAME A1 Premium Aluminum, double-butted, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger
REAR SHOCK N/A
FORK SR Suntour SF7-XCM, 100mm travel, 12": 80mm, 30mm Hi-Ten stanchions and steerer, one piece alloy lower, coils spring mcu w/ preload adj., spring assisted seals, custom paint/graphic
HEADSET 1 1/8" threadless
STEM Specialized 3D forged alloy, two bolt, 25.4mm, 10 degree rise
HANDLEBARS Alloy 25.4mm, 640mm wide, 38mm rise, 8 degree back, 6 degree up sweep, 3.2mm thick
TAPE/GRIPS Specialized Enduro, dual density Kraton
FRONT BRAKE Pro Max, alloy "V" w/ linear spring
REAR BRAKE Pro Max, alloy "V" w/ linear spring
BRAKE LEVERS Shimano EF-50, integrated
FRONT DERAILLEUR Shimano Altus FD-M310-6, top swing, 34.9mm clamp
REAR DERAILLEUR Shimano Acera RD-M340
SHIFT LEVERS Shimano EF-50
CASSETTE FREEWHEEL Shimano HG-40, 8-speed, 11-32t
CHAIN KMC X8, 1/2" x 3/32" w/ reusable Missing Link
CRANKSET SR Suntour XCM-T312, replaceable rings, Octalink spline
CHAINRINGS 42S/32S/22S
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 118mm for 50mm chainline
PEDALS Steel cage, composite body, 9/16"
RIMS Specialized/Alex HR 26, double wall w/ CNC
FRONT HUB Specialized, forged alloy, 32h, polished races, steel QR
REAR HUB Shimano FH-RM30L, cassette, 32h, QR
SPOKES 1.8mm (15g) stainless
FRONT TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
REAR TIRE Specialized Resolution, 26x2.1", 30TPI, wire bead
TUBES Specialized schraeder valve
SADDLE Specialized Aggro, kevlar sides, front and rear bumpers, 143mm width
SEAT POST Specialized alloy two bolt micro adjust head, 30.9mm
SEAT BINDER Specialized alloy w/ QR
NOTES Chain stay protector, reflectors, clear coat, owners manual
Hardrock XC Sport
FRAME A1 Premium Aluminum, double-butted TT, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger
REAR SHOCK N/A
FORK RST Capa T26ML, 80mm, 25.4mm stanchions and 1 1/8" steerer, one piece alloy lower, forged crown, coil spring mcu w/ preload adj. and mechanical LO
HANDLEBARS Specialized alloy 25.4mm, XC rise, 640mm wide, 8 degree back, 8 degree up sweep
CRANKSET Shimano FC-M341-8, replaceable rings, Octalink Spline
BOTTOM BRACKET Shimano BB-ES25, Octalink spline, cartridge bearing, 68 x 126mm for 50mm chainline
RIMS Specialized/Alex HRXC 26, double wall, CNC sidewalls
FRONT TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
REAR TIRE Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
SADDLE Specialized XC, kevlar sides, front and rear bumpers, 143mm width
NOTES N/A
Hardrock XC
FRAME A1 Premium Aluminum, ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable 98954020 alloy hanger
REAR SHOCK N/A
FORK RST Capa T26, 80mm, 25.4mm stanchions and 1 1/8" steerer, one piece alloy lower, forged crown, coil spring mcu w/ preload adj.
STEM Alloy A-head
HANDLEBARS Hi-Ten 25.4mm, 640mm wide, 32mm rise, 8 degree back, 6 degree up sweep
TAPE/GRIPS Kraton, Revo type
BRAKE LEVERS Pro-Max alloy two finger w/ adj. reach
FRONT DERAILLEUR Shimano FD-C050, 34.9mm clamp
REAR DERAILLEUR Shimano Altus RD-M310
SHIFT LEVERS Shimano RS-43 Revo Twist
CASSETTE FREEWHEEL Shimano MFHG-37, 7-speed, 13-34t mega range
CHAIN KMC Z7, 1/2" x 3/32" w/ reusable Missing Link
CRANKSET Shimano FC-TX70, square taper
CHAINRINGS 42S/34S/24S (riveted c'rings)
BOTTOM BRACKET TH cartridge, square taper, 68 x 122.5mm for 47.5mm chain line
RIMS Alex Z-1000, 26", alloy
FRONT HUB Specialized, forged alloy, 32h, polished races, alloy QR
REAR HUB Specialized, forged alloy, freewheel type, 32h, polished races, alloy QR
