Велосипед абсолютно новый, ниразу не катаный.
Рама карбон.
Есть размеры: 40 см, 45 см, 50 см.
Дербана не будет.
Фото по ссылке: https://yadi.sk/d/bj_168XAha6ca
Цена 90 000 руб.
Антон - 8 963 765 68 23 моб. Москва
Спецификация:
Fork: Fox 32 Float CTD O/B, suspension: air, damping: oil, travel: 100mm, tapered
Front derailleur: Shimano Deore M611, Direct Mount
Rear derailleur: Shimano Deore XT M 781, 30-speed
Shiftlever: Shimano Deore, SL-M 610, Rapidfire
Crankset: Shimano SLX M 672, 40-30-22 Teeth, 2-piece crankset
Bottom bracket: Shimano Press Fit SM-BB 71
Sprocket: Sram PG 1020 11-36 Teeth, 10-gear
Chain: KMC X10-93
Brake lever: Tektro Auriga, hydraulic disc brake
Brake (front): Tektro Auriga, hydraulic disc brake, 180mm
Brake (rear): Tektro Auriga, hydraulic disc brake, 160mm
Tires: Schwalbe Racing Ralph Performance, 27,5×2,25, Presta valve
Rim: DT Swiss 466d Disc, alloy-double wall
Hub (front): XLC EVO Disc, axle 15mm
Hub (rear): XLC EVO Disc axle, 142/12mm
Spokes: black 2,0mm
Handlebar: Haibike Top-Flatbar, oversize, 720mm
Grips: XLC Sport lock on grips
Stem: Haibike Alu A-Head
Headset: VP 62AC, semi-integrated, tapered
Saddle: Selle Italia X1
Seatpost: Haibike 27,2mm, Alu-Patent, clamp with hexagon-clamping
Frame: UD Carbon, 27,5″, Advanced Multiforming Technology, Monocoque
