FRAME / NEW 2015 META HT Trail 29’’, Alloy 6061 triple butted, Top tube hidden cable path, tapered headtube
FORK / SUNTOUR Raidon XC LO R 29, Air Spring, Hydraulic speed lock, Rebound adjustment, Travel 120mm (80mm on XS), 1’’1/8 steerer, 9mm front axle
HEADSET / ALPHA Semi integrated,tapered ZS44/56, 1’’1/8 crown race, ball retainer
STEM / ALPHA, Alloy 2014 Forged, 60mm, O° rise, Ø31,8mm
BAR / ALPHA, Alloy 6061 double butted, 20mm rise, 730mm, Ø31,8mm
GRIPS / COMMENCAL lock on, Ø30mm, soft compound, Neon Orange logo
BRAKES / AVID DB1 160mm/160mm
SHIFTERS / SRAM X5 2x9 spd
FRONT MECH / SRAM X5 high direct mount 2 spd
REAR MECH / SRAM X5 9 spd medium cage
BOTTOM BRACKET / ISIS BB 68mm, sealed bearings
CRANKS / ALPHA Forged 2x9, 22/36 t, 170mm on S, 175mm on M/L/XL
CHAIN / YABAN 9 spd
CASSETTE / SRAM PG950 11-34 t
RIMS / ALPHA 29’’ 32H double wall, 23mm, pin joint, Non Tubeless
HUBS / ALPHA 32H, Light Quick Release skewer, 9mm front, 10x135mm rear
SPOKES / Spoke Steel 1,8mm black - nipple brass 12mm black
TIRES / MAXXIS Ikon 29x2.2, 60 tpi
SEATPOST / Alloy no offset Ø31,6mm, 350mm
SADDLE / Commencal Meta Trail, Crmo rails
ACCESSORIES / Chainstay protector, no pedals
COLOUR / Orange Neon, Matt finish
BIKE WEIGHT(kg/lbs) / 12,9 kg / 28,4 lbs
