Пробега не больше 100км.
Triple-butted, tapered 7075-T6 aluminium reduces weight by removing material from places it is not necessary.
• Bead blasted finish for strength
• Polished grip area for better grip adhesion
• No rise with sweeps comparable to the riser bars
• 762mm length provides leverage and slows steering at high speeds to add stability
• Marks on end of bars to custom cut length
• Can be cut down to 660mm length with room for controls
• Lightweight DH strength at 303 grams at full width but light enough for singlespeeds
• Laser etched logos for durability
• 31.8mm clamp size only
2000р без торга.
icq 172217831
