Fixed Gear Club - Страница 84
Страница 84 из 2584 ПерваяПервая ... 34547479828384858689941141341842843845841084 ... ПоследняяПоследняя
Показано с 831 по 840 из 25838
Тема: Fixed Gear Club
  1. #831
    Сейчас ваш статус Аватар для PERFORATTOR
    ☑ Yes ⁤ ❒ No⁤ ⁤ ⁤ ⁤ ⁤ ⁤ ⁤ Stern Motion 29 2019 ⁤⁤ ⁤ ⁤ ⁤ ⁤⁤ ⁤ ⁤ ⁤ ⁤ ⁤ Outleap Hardway 2021 ⁤ ⁤ ⁤Seba FR2 + 3x100 frame⁤ ⁤
    из-под второго реактора ЧАЭС
    потому что сейчас такие не выпускают и не продают т.к. в спорте есть контакты
    выпускают только "туклипсы" типа для фиксеров
    картинки я находил при желании
    Не. И те, и те имели место.
    https://en.wikipedia.org/wiki/Bicycle_pedal
    To improve the performance of the quill pedal toe clips were added. The toe clip is a thin metal or plastic attachment to the front cage of the pedal. The toe clip is shaped like the toe of a shoe and its function is to prevent a cyclist's shoe from slipping off the pedal during the forward pedaling motion.[1] The clip is generally made of metal or high impact plastic. A further enhancement of the quill pedal was modifying the toe clip to allow a strap and buckle to go around or through both the pedal and the toe clip to encircle the cyclist's foot on the top of the pedal.[1] This strap is generally made of leather or nylon.
    Mikashima track pedal
    To further improve the quill pedal's efficiency a "cleat" was developed. This cleat consists of a small metal or plastic attachment to the cyclist's shoe. The cleat is slotted and is adapted to engage a quill section of the bicycle pedal. The use of the slotted cleat enhances a cyclist's ability over that provided by toe clips and strap, enabling for greater pedaling efficiency.[1] Although quill pedals can be used with smoothed-soled cycling shoes or ordinary shoes, they were designed to be used with cycling shoes which had a slotted shoeplate attached to its sole. The disadvantage with this system is that to remove the shoe from the pedal a rider had to reach down and loosen the strap by hand or leave the toe strap loose and thus give up some efficiency. This type of pedal and pedal setup was common for racing cyclists until the mid to late 1980s
    Там есть фото трэковых педалей 70-х без шипов. Сейчас это типа анахронизм, ещё более анахроничный, чем башмак с шипом, ну или просто хорошо забытое старое.
    Во сколько сейчас контакты с башмаками обойдутся, цена/качество на 44.5 или 45?
  2. #832
    в спорте только такие как я описал.
    педали шимано типа 105 и туфли простые типа шоссейные не думаю что очень дорого
    ---------- Добавлено в 22:07 ---------- Предыдущее сообщение было в 22:04 ----------
    PERFORATTOR, шип то на туфле был
  3. #833
    В спорте и те, и те.
    http://www.classiclightweights.co.uk...icattaneo.html
    http://www.classiclightweights.co.uk...teve-comp.html
    шип то на туфле был
    Ну.
    Хера се... только педали 6.000.
  4. #834
    В спорте годов с 60-х минимум шип-туфля плюс туклипс. Может раньше. Я застал переход с туклипсовмна контакты - начало 90-х.
    http://www.chainreactioncycles.com/m.../rp-prod109699
  5. #835
    Без 5-ти минут веломаньяк! Аватар для Lakmuskosh
    Fuji declaration 2013 fix
    Екатеринбург
    Я был оптимистичен про среднюю 35 на разделке 9 км. 33 реальнее -это же фикс. На нем совсем медленно.
    Все таки 35 км/ч как-то мало для разделки в 9 км. У меня на разделке 20 км, средняя 33 км/ч на фиксе с моей кабинетной мускулатурой. И это на городской стоковой передаче 46/16 (2,75), хотя рельеф был не очень холмистый, можно было 46/15 попробовать (3,07). В контактах spd
    Последний раз редактировалось Lakmuskosh; 05.11.2015 в 08:12.
  6. #836
    Lakmuskosh, ну вот, а 35 на 2 км/ч больше, чем у Вас
  7. #837
    Последний раз редактировалось Babak; 15.05.2017 в 23:55.
  8. #838
    Мне кажется лучше определиться либо в бар в нормальной обуви либо гонки.
  9. #839
    Тогда тебе в другую ветку
  10. #840
  1. fixed gear mtb
    Ответов: 24
    Последнее сообщение: 07.04.2026, 20:49
