Новые МТB педали: LOOK S-TRACK [2013] - Страница 8
Показано с 71 по 80 из 106
Тема: Новые МТB педали: LOOK S-TRACK [2013]
Древовидный режим
    По умолчанию Новые МТB педали: LOOK S-TRACK [2013]
    S-Track pedal : LOOK's latest innovation
    On the first of Eurobike, LOOK launched its latest MTB pedal, the S-Track.
    Consistent with the innovation strategy to which LOOK is committed,
    the S-Track is the first MTB pedal designed to be used with a removable
    cage for a multipurpose use.
    A featherweight pedal with a double platform surface without precedent
    in the MTB world, it should soon become a must-have !
    Пресс-релиз (PDF 12Мb)
    Five years after it first debuted its Quartz mountain bike pedal, Look has taken another stab at the dirt market with its new S-Track.
    The revised model is based loosely off the Quartz’s dual-spring design, but features a number of updates intended to resolve the old
    pedal’s persistent issues.
    The Quartz saw a bit of adoption at the highest level of cross-country racing, and Jaroslav Kulhavy recently raced it to Olympic gold,
    but the pedal never caught on in a market dominated by Shimano and Crank Brothers. Setup was always a pain, as the Quartz required
    careful cleat shimming to avoid an overly floaty feel, and was prone to involuntary release if not set up correctly. For consumers keen
    on ease-of-use, it wasn’t the best option.
    Look says that those problems are now gone. The new S-Track is designed to eliminate that floaty, soft feel even without any cleat
    shimming, and should a rider decide to take the time to perfect the setup (and thus provide the best possible contact area), the cleat
    shims are now exceptionally easy to use. It is easier to create good contact between shoe and pedal, but that contact is no longer
    required for the pedals to function.
    The specs
    Look claims that the S-Track has the largest surface area on the market at 460mm2. Look has improved cleat-to-pedal contact, which
    is what eliminates the careful shimming necessary with the Quartz. The contact area is stainless steel, and the cleat itself uses elastomer
    pads for a stable feel and optimal power transmission, according to Look.
    The torsion bar, which supplies the pedal tension, is S-shaped and is now more rigid. Look says the shape offers up better mud evacuation
    as well.
    The new cleats and pedals won’t retrofit with the Quartz models. Both the cleats and pedal surface get what Look calls the “Dynamic Cleat
    System,” basically grooves and shapes in both surfaces designed to provide optimal mud evacuation. The new cleats will retail for the same
    price as the old model: $22 a pair.
    In a nod to the more adventurous, the S-Track will be available with a removable cage, either in composite or aluminum, depending on the model.
    Speaking of models, three will be available: The regular S-Track, the S-Track Race, and the S-Track Carbon-Ti.
    The S-Track is the star, at least in my eyes. At only $109.99, it has a Chromoly axle, weighs 320 grams, and features composite deflectors.
    The Race version is more than twice the price at $209.99, and contrary to its name is intended for extra durability rather than racing.
    It features a Chromoly Plus axle, weighs 326 grams, uses an injected carbon body, and features aluminum deflectors.
    The Carbon-Ti drops the weight down to 280 grams, features an injected carbon body and titanium axle, plus carbon deflectors.
    A pair will run $369.99.
    An aluminum cage is available for $99.99, weighs 296 grams, and comes in black or red. The composite cage is $49.99, weighs 148 grams,
    and only comes in grey.
    LOOK S-TRACK + Christoph Sauser
    Последний раз редактировалось pavlinux; 05.09.2012 в 00:04.
  1. Продам Продам новые МТВ-педали LOOK Quartz Carbon
    от Pyghik в разделе Крутим
    Последнее сообщение: 01.07.2012, 22:30
  2. Продам Новые шоссейные педали Look KEO 2 MAX Carbon
    от iGordienko в разделе Крутим
    Последнее сообщение: 26.05.2012, 10:49
  3. Продам --------
    от SHIN в разделе Крутим
    Последнее сообщение: 01.05.2012, 22:32
  4. Контактные педали Look Keo
    от McArcher в разделе Технические вопросы
    Последнее сообщение: 18.05.2007, 16:42
  5. неспешно куплю новые педали
    от Чингачгук в разделе Крутим
    Последнее сообщение: 09.05.2006, 13:20
