может они готовят к выкату велофлагман? а тут решили проверить новые фичи на старом пока
Новый флагман на старом андроиде? Сомнительно. Надо кстати проверить температуру они впилили как было заявлено еще до выпуска 650.
Напомню все хотелки юзеров, может что-то еще всплывет:
Training
- Training Targets and detailed workouts, HR target AND a cadence target for an interval [1] [2]
- Training load and recovery advisor (shared with v800) [1] [2] [3]
- Adding more power zones [1]
- Fitness test [1]
- Orthostatic test [1]
- Automatic lap setting based on GPS position instead of fixed distance or fixed time [#23⬇︎]
- Adding TrainingPeaks metrics of Normalized Power® (NP®), Intensity Factor® (IF®) and Training Stress Score®(TSS®)
Set up
- Add names for different bikes [1]
- Input the distance (odometer) value of each of the 4 Bikes [1] [#2⬇︎]
Maps/Routing
- Half screen of map and half screen with selectable datafields [1]
- Latlong coordinates on the map screen [1]
- Start/follow route with session started [1]
- Change the route during the ride without having to stop the workout [#21⬇︎]
- GPS tolerance/sensitivity to prevent repeated "Route Found" messages whenever the V650 loses and then reacquires the route [#2⬇︎]
- View the map screen when recording is paused [#6⬇︎]
- Turn by turn navigation [#23⬇︎]+1
Polar Flow
- Full integration with Flow (including the ability to change settings in Flow) [1]
- Merging sessions in Polar Flow [1]
Functionality
- Target zone alarm should beep continuously until heart rate (or power, cadence, speed, or any other variable) returns to the target zone [#2⬇︎]
- Pause the ride and turn unit off, have lunch, turn on again and resume the ride [1] [2]
- Smart phone connectivity with complete set up/configuration and notifications [#3⬇︎] [1]
- Automatic uploads [1]
- Recording of incline data (in Flow) [1]
- Support for trainers like the Wahoo KickR (Snap) or Tacx [#3⬇︎]
- 3rd party power meter support [1]
- Support for Shimano Di2 and the SRAM RED eTAP System to monitore shifting behaviour [#5⬇︎]+1
- Support for Strava live segments [#15⬇︎]+1
Misc
- Compass [1]
- Temperature indication, as a data field to display and analyse in Flow [1] [2] [3] [4] [#2⬇︎]
- "Bell" added to the pull down menu or a new pull up menu could be added [1]
- Live tracking/friend tracking system [1] [#36⬇︎]
- Save altiitude data when known at certain locations (like your home) to speed up calibration [1]
- Sensitivity of the touch screen when used with gloves [1]
Последний раз редактировалось lmv_vlg; 25.04.2018 в 16:25.
Если так, то плохо. Если не ошибаюсь ранее они как раз таки добавили обратный отсчет в одном из обновлений.
Учитывая, что Live Segment работает только со Strava Premium, он уже лично мне мало интересен.
NP реально нужная вещь, особенно для XC где мощность не так стабильна как например в шоссе. Так же видел, что добавили, TSS и IF, тоже лишними не будут, но будут ли они отображаться во FLow?
Полар красава ночные билды релизит ) из файла зип:
То что есть обновление хорошо, а то что так и недопилили нормальную синхронизацию через bluetooth, это хреново.
Раньше хоть раз на 10-й синхронизировался, через телефон, а теперь вообще перестал...
Теперь тренировки только через комп сбрасывать, это бесит...
Ездил в Турцию и в итоге писал тренировки паралельно через garmin fenix, а с полара тренировки смог слить только по приезду домой
Последний раз редактировалось zimoval; 25.04.2018 в 19:39.
Или пароноидальной безопасности, типа как в Xiaomi, Android 8 близок к ним.
---------- Добавлено в 21:17 ---------- Предыдущее сообщение было в 21:12 ----------
Да ладно, просто признайся, что нравиться что она всегда больше средней за 20 минут.
И как раз в кросскантри, точнее даже в XCO, оно малоинформативно, так как 4-е степени
"сжирают" все креатинфосфатные, алактатные и треть анаэробных ускорений.
Последний раз редактировалось pavlinux; 25.04.2018 в 21:27.
Блин, а разработчики Garmin об этом не знают....
С гармином проблем нет, с другими моделями от полар таких проблем нет, вот только V650 выделился!
Знал бы изначально что с ним такой головняк и в плане настройки он такой куций, его точно не купил бы!
з.ы. "благодаря" моему отзыву минимум двое моих знакомых отказались от покупки V650
Оooooo, ты б видел что творилось с блютузом когда вышел Garmin Edge 1000 и Fenix 5,
я из-за этих Феников продал Xiaomi Redmi 4 и купил Sony Xperia X Perf.
Garmin Edge 1000 купил где-то в июне 2015, до августа 2016 по блютузу грузилось раз в неделю.
Хотя V650 уже тоже не молодой, могли бы и доделать.
Последний раз редактировалось pavlinux; 25.04.2018 в 21:35.
Поехал тоже проверить, что нового добавили и что поменялось:
1. Добавилась возможность калибровать паверметры. Для меня это значимый плюс, раньше приходилось перед заездом доставать телефон и проводить калибровку через родную прогу паверметра.
2. Расширилась поддержка самих паверметров. Конкретно в моем случае, с Quarq'а теперь снимается не только мощность, но и баланс по ногам. Тоже плюс, у меня оказывается дисбаланс гораздо больше чем я думал, будем исправлять)
3. Поменялся алгоритм завершения заезда. Вернулись к старой схеме, без 3-сек подтверждения. Минус, можно случайно промахнуться и завершить заезд когда этого совсем не хочется.
4. Добавился угломер по данным GPS. Работает по моему с большим запаздыванием, чем с датчиком скорости. Отставание от реальности примерно 5-10 секунд.
5. Добавились новые метрики, NP, TSS, IF. Первого очень не хватало, остальные два тоже не будут лишним. Отображаются как на приборе, так и в Polar Flow.
После выхода нового Garmin 130 загорелся махнуть его V650, но после этого обновления, аргументы для замены сошли на нет.
