Выпустили прошивку.
[q]
Changes made from version 10.18 to 10.19:Changes made from version 9.11 to 10.18:
- Fixed memory leak issue that could cause a crash
[/q]
- Added Garmin Share. Share your workouts, courses, and waypoints between compatible Garmin devices.
- Added ecosystem-wide Garmin Coach support. Train for an event, achieve a milestone, or improve your fitness with dynamic Garmin Coach training plans for runners and cyclists.
- Added GroupRide awards and climb competitions.
- Added road hazards support. Get alerts for road hazards reported by fellow cyclists and contribute your own edits.
- Added wind and stamina adjustments to Power Guide.
- Added surface type support including on the map, in-ride unpaved road alerts, and post-ride summary.
- Added Wi-Fi map download support.
- Added revamped Course Creator.
- Updated grade algorithm to be much more responsive.
- ClimbPro
- Fixed climb clusters failing to display climb details.
- Fixed an issue where the climb list page could highlight the incorrect current climb.
- Fixed climbs drawing on a course when ClimbPro is disabled.
- Retained the setting for the ClimbPro, Segment, and PowerGuide slider between page uses.
- Added support for India basemap.
- Added gear presets for SRAM 12 speed cassettes.
- Added a QR code to quickly pair a Strava account with Garmin Connect.
- Added search alias support to improve location searching.
- Added course search to the search bar.
- Fixed USB connection detection when coming out of suspend mode.
- Fixed crash that could occur when saving the ride.
- Fixed incident detection countdown timeout notification priority over any other notifications.
- Fixed infinite elevation calibration prompt following a manual calibration.
- Removed tone from elevation calibration prompt.
- Fixed mute toggle interactions on the notifications widget.
- Fixed pausing navigation.
- Improved speed of city search.
- Improved phonetic and hand-writing keyboard input.
- Fixed ride button failing to show after receiving and reviewing a Connected POI.
- Fixed friendly name for phone pairing.
- Fixed issue where hazards in China could appear offset on the map.
- Set minimum backlight level to retain screen visibility after backlight timeout expires.
- Persisted backlight level setting through battery saver enable and disable.
- Fixed battery remaining time estimate not updating when toggling Hide Map option in battery saver menu.
- Fixed display of battery level when it dropped below 5%.
- Fixed small roads on map being drawn too thick.
- Fixed behavior of menus from popping back to previous page to remaining on page after data entry.
- Fixed an issue where British coordinates could not fully be entered with the keyboard.
- Improved layout of post-ride highlights page.
- Fixed various crashes and freezes.
Но вот же штопаный Гармин, с этой прошивкой снова - прям как с 1030! - стали отваливаться фонари Varia. Примерно через пару минут после начала поездки, просто перестают светить, пока не передернешь light network on/off, и не выберешь вручную "connect" у конкретных фонариков.
Последний раз редактировалось pavlinux; 25.09.2024 в 15:48.
Но работает же на все сто. Перешёл и не жалею.
- Wi-Fi Sync Issues Since 10.18
- Corrupt FIT file won't upload from 1050 to Garmin Connect and Strava
- Varia Radar sound on while Edge 1050 sound off?
- Saved outdoor activity not showing any map data
- Issues with Grade and Elevation Calculation
- Spontaneous shutdown - это беда всех гарминов. Длинные маршруты с полноценной навигацией почти всегда подвесят прибор
- White screen in my Garmin Edge 1050 after the course map downloaded from my mobile with Komoot premium application
Длинные заезды (5+ часов) я уже, наверное, лет 6-7 точно, пишу на два прибора
Последний раз редактировалось pavlinux; 26.09.2024 в 12:48.
Какими картами в нём пользуетесь? Дороги России?
Навигация Garmin 1050 не сильно изменилась со времен модели 1000,в лесу с gpx невозможно ездить,попробовал кароо3 вот там другое дело с навигацией уже можно ездить по лесу,конечно есть еще всякие мелкие недостатки в этом karoo,но в лесу он оказался на голову выше чем гармин 1050459408650_8823987364280873_4244843369616681793_n.jpg
Хм, за 4 года 830й ни разу не подвесил длинный заезд.
Нафигация разве что больше батарею жрет, ибо бывает трек не совпадает с тем, как ты едешь (или как разметили гонку), и гармин начинает переделывать маршрут и тратит батарею.
Раз я свернул не туда, ибо разметка была неправильно развешана и я поехал не тот маршрут, который собирался (и который был загружен). И за полтора часа гармин сожрал процентов 20-25 батареи наверное.
