Gt Avalanche! + вилка? - Страница 3
Показано с 21 по 30 из 37
Тема: Gt Avalanche! + вилка?
  1. #21
    <table border="0" cellpadding="0" cellspacing="0" width="90%" align="center">
    <tr>
    <td class="vbquote">
    <table border="0" cellpadding="0" cellspacing="0" width="100%">
    <tr>
    <td class="vbquote" width="75" valign="bottom">
    <table border="0" cellpadding="0" cellspacing="0" width="50px">
    <tr>
    <td class="vbquote" width="28" valign="top">[img]style_images/poporange2/quotes/quote-top-left.gif[/img]</td>
    <td class="vbquote" width="100%" style="background-image: url('style_images/poporange2/quotes/quote-bg.gif'); background-position: center;" valign="middle">Цитата:</td>
    <td class="vbquote" valign="top">[img]style_images/poporange2/quotes/quote-top-right.gif[/img]</td>
    </tr>
    </table>
    </td>
    <td class="vbquote" align="left" style="background-image: url('style_images/poporange2/quotes/quote-lr-bg.gif')" valign="bottom"></td><td class="vbquote" width="0" align="left" valign="bottom">
    <table border="0" cellpadding="0" cellspacing="0" width="200">
    <tr>
    <td class="vbquote" valign="top">[img]style_images/poporange2/quotes/quote-by-left.gif[/img]</td>
    <td class="vbquote" width="100%" style="background-image: url('style_images/poporange2/quotes/quote-by-bg.gif')" align="left" valign="middle" nowrap="nowrap">(ленивый @ 11.04.2006 23:57) [snapback]107868[/snapback]</td>
    <td class="vbquote" valign="top">[img]style_images/poporange2/quotes/quote-by-right.gif[/img]</td>
    </tr>
    </table>
    </td><td class="vbquote" width="100%" align="right" valign="bottom">
    <tr>
    <td class="vbquote" width="100%">
    <tr>
    <td class="vbquote" style="background-image: url('style_images/poporange2/quotes/quote-top-bg.gif')" width="100%" valign="middle"></td>
    <td class="vbquote" align="left" valign="top">[img]style_images/poporange2/quotes/quote-top-right-10.gif[/img]</td>
    </tr>
    </table>
    </td>
    </tr>
    </table>
    </td>
    </tr>
    </table>
    <tr>
    <td class="vbquote" width="10" style="background-image: url('style_images/poporange2/quotes/quoting-left.gif')"></td>
    <td class="vbquotemain" width="100%" valign="top"></td>
    <td class="vbquote" width="10" style="background-image: url('style_images/poporange2/quotes/quoting-right.gif')"></td>
    </tr>
    <tr>
    <td class="vbquote" width="10" style="background-image: url('style_images/poporange2/quotes/quote-left-bg.gif')"></td>
    <td class="vbquotemain" width="100%" valign="top">1) реально, но я (так как ленивый) отдал в мастерскую, чтобы заодно и якорь поставили.
    2) да намертво, снять нельзя. Хотя я видел в продаже многоразовый, но вряд ли у тебя такой.
    3) х.з. ... ставить якорь не умею, поэтому отдал мастеру (вся работа рублей 100-150). Кстати может кто действительно расскажет как самому ставить и чтоб не запороть.</td>
    <td class="vbquote" width="10" style="background-image: url('style_images/poporange2/quotes/quote-right-bg.gif')"></td>
    </tr>
    <tr>
    <td class="vbquote" width="10" valign="bottom">[img]style_images/poporange2/quotes/quote-bot-left.gif[/img]</td>
    <td class="vbquote" width="100%" style="background-image: url('style_images/poporange2/quotes/quote-bot-bg.gif')"></td>
    <td class="vbquote" width="10" valign="bottom">[img]style_images/poporange2/quotes/quote-bot-right.gif[/img]</td>
    </tr>
    </table>
    </td>
    </tr>
    </table>
    Вот здесь вроде описано как это делать.
    Кому интересно.
    http://veloroad.spb.ru/forum/viewtopic.php?t=5685
  2. #22
    Thumbs up
    Господа ! :huh:
    Шток - подпилили, якорь вбили, ставлю дома вилку...
    При разборке было множество колец и подшипников, назначение которых я теперь вполне ясно представляю, кроме одного кольца ! Имеет оно конусообразную форму, из пластмассы, с разрезом... КУДА ЕГО СТАВИТЬ ? )))
    Думал что можно и без него - ан нет, при сборе вилка в рулевом стакане люфтит. Нужен ваш совет !!
    Изображения Изображения
    [b] be
    Reaching the highest point will only get you to another mountain. It is not to say what is beyond that.
    GT is the Power!
  3. #23
    под верхнюю крышку, узкой частью вниз
  4. #24
    Между верхним конусом и рулевой трубой, это распорное кольцо как раз убирает люфт.
  5. #25
    Thumbs down
    Это надо прям под верхний подшипник загонять ? :464:
    [b] be
    GT is the Power!
  6. #26
    <tr>
    <tr>
    <tr>
    </tr>
    </table>
    </td>
    <tr>
    <td class="vbquote" width="100%" style="background-image: url('style_images/poporange2/quotes/quote-by-bg.gif')" align="left" valign="middle" nowrap="nowrap">(neoz @ 15.04.2006 00:10) [snapback]108833[/snapback]</td>
    </tr>
    </table>
    <tr>
    <tr>
    </tr>
    </table>
    </td>
    </tr>
    </table>
    </td>
    </tr>
    </table>
    <tr>
    </tr>
    <tr>
    <td class="vbquotemain" width="100%" valign="top">Это надо прям под верхний подшипник загонять ? :464:</td>
    </tr>
    <tr>
    </tr>
    </table>
    </td>
    </tr>
    </table>
    Смотри , запрессовал нижний конус на вилку, На него ставишь смазанный подшипник, вставляешь рулевой шток в раму , сверху опять смазанный подшипник , на него верхний конус , а сверху острым углом вниз , между конусом и рулевой эту деталь ( ещё соответственно снизу и сверху пыльники пластмассовые , которые от влаги и пыли защищают). Дальше ставишь проставочные кольца и вынос .
    Притягиваешь его верхним болтом , центруешь руль и окончательно затягиваешь.
    Вроде всё правильно , если что упустил поправьте.
  7. #27
    Thumbs down
    vova095
    Отдельное рукопожатие за столь подробный ответ ! :tanksmile:
    Ща приеду - реализую ...
    Добавлено позже (15.04.2006 22:02):
    Итак, продолжаем нашу фотобиеннале 2006 ...
    НИКАК ! )
    На двух фото представлена последовательность насаживаемого "материала", проставочные кольца идут сверху, их на фото не ставил.
    Какое из представленных решений - верное ? :golod_295:
    • Тип файла: jpg 1.jpg‎ (60.0 Кб, Просмотров: 13)
    • Тип файла: jpg 2.jpg‎ (64.4 Кб, Просмотров: 14)
    [b] be
    GT is the Power!
  8. #28
    на первой фотке верно
  9. #29
    Thumbs up
    А так эта хрень и должна торчать ?
    • Тип файла: jpg 1_1.jpg‎ (70.7 Кб, Просмотров: 18)
    [b] be
    GT is the Power!
  10. #30
    нет. тут явно не хватает крышки рулевой колонки. а так ты раздавишь это кольцо.
    ...Занятия фигней на рабочем месте развивают боковое зрение, слух, реакцию и бдительность в целом.
  1. вилка на GT Avalanche 1.0 Disc (2009)
    от aarlan в разделе Технические вопросы
    Последнее сообщение: 08.09.2009, 12:55
  2. вилка на GT Avalanche Pro (2008)
    от xxff в разделе Технические вопросы
    Последнее сообщение: 29.05.2009, 08:50
  3. Вилка на GT Avalanche
    от meist07 в разделе Технические вопросы
    Ответов: 38
    Последнее сообщение: 15.02.2009, 20:16
  4. ВИЛКА Spinner Edge v1 (c GT Avalanche 2.0 d)
    от Yogurt в разделе Технические вопросы
    Последнее сообщение: 12.11.2005, 22:57
  5. вилка на GT Avalanche Pro (2008)
    от xxff в разделе Выбор велосипеда
