<div class='quotetop'>Цитата(mckinley @ 25.12.2008 01:00) <{POST_SNAPBACK}></div>Ненене, Дэвид Блейн (с)
Even though the air spring compensator is not actively compressed by the
compression rod and piston, over time this material will degrade and lose its
effective spring rate from being compressed by the air pressure in the fork and
will need to be replaced periodically. The 80mm R7 will use the 60mm long air
spring compensator, all other MRD forks, R7100mm and both Minute 100 and
130mm, will use the shorter 40mm air spring compensator.
Так что не проставка.
[/b]
Ответить с цитированием
