Наши байки: Ragley Blue Pig Kona Lana'i Da Bomb Cherry Bomb Eastern Jane Author Stylo |||архив: Kona Lava Dome DMR Ex[alt]
Появился в наличии еще Hardrock Sport (без диска), но через недели две обещают подвезти модель с механическим диском, стоит ждать? или вибрейки там нормальные?
FRAME
Specialized A1 Premium Aluminum, fully butted, formed TT, Double ORE DT, externally relieved HT, reinforced disc mount, forged dropouts w/ replaceable hanger
REAR SHOCK
FORK
SR Suntour SF10-XCT-V2-MLO, 80mm, 1pc. alloy lower, 28mm Hi-Ten stanchions, mechanical LO, coil/mcu spring w/ preload adj., size-specific spring rates, spring assisted seals
HEADSET
1-1/8" threadless, loose ball
STEM
3D forged alloy, 10 degree rise, 25.4mm clamp
HANDLEBARS
Alloy riserbar, 25mm rise, 640mm wide, 8 degree back sweep, 7 degree up sweep
GRIPS
Specialized Enduro, dual compound Kraton, no flange, 131mm
FRONT BRAKE
V brake, alloy linear pull, 1pc. pad
REAR BRAKE
BRAKE LEVERS
Alloy, linear pull
FRONT DERAILLEUR
Shimano Altus, 34.9mm clamp
REAR DERAILLEUR
SRAM X-4, mid cage
SHIFT LEVERS
SRAM X4-R trigger
CASSETTE
SRAM PG-820, 8-speed, 11-32t
CHAIN
KMC X8 w/ reuseable Missing Link
CRANKSET
SR SunTour, Octalink spline
CHAINRINGS
42S x 32S x 22S replaceable
BOTTOM BRACKET
Shimano BB-ES25, Octalink spline, cartridge bearing, 68mm x 118mm
PEDALS
Steel cage, composite body, 9/16"
RIMS
Alex RH, 26", pinned, alloy double wall, CNC sidewalls, 32h front and rear
FRONT HUB
Forged alloy, double sealed, ground race, steel QR, 32h
REAR HUB
Shimano RM30, forged alloy, double sealed, ground race, cassette, 32h
SPOKES
2mm (14g) stainless
FRONT TIRE
Specialized Fast Trak LK Sport, 26x2.0", 60TPI, wire bead
REAR TIRE
INNER TUBES
Schraeder valve
SADDLE
Specialized XC, Body Geometry, 143mm width, front and rear bumpers
SEATPOST
Alloy two bolt, 12.5mm offset, micro adjust, 30.9mm
SEAT BINDER
Alloy QR, nylon washer
NOTES
Chain stay protector, reflectors, clear coat, owners manual
спасибо!
короче понял, что нужно брать Кону и стараться падать вбок![]()
