Тесты Friction Facts - Страница 2
Показано с 11 по 20 из 96
Тема: Тесты Friction Facts
Древовидный режим
    По умолчанию Тесты Friction Facts
    Результаты и отчеты тестирования которые представлены на сайте Friction Facts
    http://www.friction-facts.com/test-r...report-package
    When combined, the Friction Facts reports can save you up to 21 watts, simply by selecting the fastest chain,
    pulleys, bottom bracket, and pedals, and performing the proper techniques. This is upwards of almost 8% of 'free' power.
    The Report Package also includes a quick-read "cheat sheet" of summary results and top performing components.
    В комбинация отчетов тестов Friction Facts поможет вам сэкономить до 21 Ватта
    просто выбирая самую быструю цепь, ролики, каретку и педали.
    (сразу предупрежу: педали в тестах только шоссейные Crank Bros Eggbeater 3, Look Keo Blade Carbon,
    Mavic Race SL Ti, Shimano Ultregra, Speedplay Zero SS, Time I-Clic 2 Carbon)
    Пакет отчётов включает:
    • 10 Ways to Increase Drivetrain Efficiency - Summary of all Efficiency Reports in one concise document
    • Chain Lube Efficiency Tests, 4+ watts savings, 55 lubes tested.
    • Cross Chaining and Chainring Size Efficiency Report, 3 watts savings.
    • Oversized Derailleur Pulley Efficiency Test, 3 watts savings, Berner Pulleys tested.
    • 11T Derailleur Pulley Efficiency Test, 1.3 watts savings, 19 pulleys tested.
    • Bottom Bracket Efficiency Test, 1.8 watts savings, 35 bottom brackets tested.
    • Pedal Efficiency Test, 1.2 watts savings, 6 pedals tested.
    • Effects of Chain Wear, 2 watts savings
    • Effects of Chain Break-in, 1 watt savings
    • Chain Efficiency, 5 Manufacturers w/ Factory Lube, 3.12 watts difference found between the most and least efficient new chains
    • Chain Efficiency, 5 Manufacturers After Re-Lube, 0.63 watts difference after re-lube
    • Effects of Rider Power Output on Chain Efficiency
    • Dirty Chain Efficiency Test
    • Dry Chain Efficiency Test
    • Belt Drive vs Chain Drive Efficiency Test
    • CS3 Auto Chain Luber Efficiency Test
    • Bearing Lubricant Efficiency Test
    Последний раз редактировалось pavlinux; 24.12.2016 в 14:38.
  1. Ответов: 7
    Последнее сообщение: 12.12.2016, 08:44
  2. Начинаем сбор заказов на KHE 2008
    от ОМНИ БАЙК в разделе Новости
    Последнее сообщение: 23.09.2007, 15:42
  3. Соловки сбор инфо
    от freehouse_ в разделе Туризм
    Последнее сообщение: 17.01.2007, 23:40
