Куплю [Куплю] Новую вилку DT Swiss XRM 100 TS Carbon - 9mm QR - Страница 2
Показано с 11 по 16 из 16
Тема: [Куплю] Новую вилку DT Swiss XRM 100 TS Carbon - 9mm QR
Древовидный режим
    По умолчанию [Куплю] Новую вилку DT Swiss XRM 100 TS Carbon - 9mm QR
    Куплю в Москве DT Swiss XRM 100 TS Carbon - 9mm QR
    вилка нужна новая и пока только такая c таким дизайном http://www.chainreactioncycles.com/r...r/rp-prod81107
    rapmixtare@mail.ru
    DT Swiss XRM 100 TS Carbon Forks
    The XRM fork is perfect for the XC rider looking for high performance with Twin Shot damping technology. The XRM 100 fork will meet all your XC riding needs and anything the trail will throw at you.
    Specifications:
    Weight: 1550g
    Travel: 100mm
    Dropout: 15mm
    Material Lowers: Torsion Box Magnesium
    Spring System: ABS
    Damping System: Twin Shot
    Remote: Yes
    Crown: Carbon UD Finish
    Steerer: Tapered 1.5" - 1 1/8" Carbon
    Steerer Expander: Yes
    Ride Height: (+/- 3mm): 475mm
    Fork Offset: 40mm
    Max Tyre Diameter: 690mm
    Max. Diameter at Tyre Width: 670mm
    Max Tyre Width: 65mm
    Max Recommended Rider Weight: 110kg
    Brake Mount: PM6" max. 210mm
    Technologies:
    ABS: Auto Balancing Spring – a high performance air spring system. Both the positive and negative air chamber are set up to the rider weight via a single valve.
    Carbon Crown: Crown and steerer are a unit of high modulus UD carbon. The internal rib reinforcements make it safe and stiff.
    Torsion Box: The two piece, hollow construction of the arch creates a very light and stiff magnesium lower.
    Twin Shot: DT Swiss's sports chassis. All dials can be comfortably reached by the rider. The damping unit is placed in the upper right stanchion, allowing for ideal cooling of the damping oil. Because of this, the system needs very little damping oil which in turn leads to a low overall weight of the fork. Open mode – full travel is used. Climb mode – for technical climbs, fork partially locked and lowered by 30%. Lockout – for starts, sprints and tarmac, 100% locked with a blow-off.
    Buy DT Swiss XRM 100 TS Carbon Forks - 15mm iRWS from Chain Reaction Cycles, the worlds largest online bicycle store.
    Изображения Изображения
    Последний раз редактировалось south; 13.01.2015 в 21:07.
  1. Продам Вилка 26" DT Swiss XRM 100 TS Carbon - 9mm QR ПРОДАНО
    от Enlyl в разделе Вилки и амортизаторы
    Последнее сообщение: 06.05.2015, 16:00
  2. Продам Вилку DT Swiss XRM 100 TwinShot 26"
    от M_P_S в разделе Вилки и амортизаторы
    Последнее сообщение: 08.07.2014, 20:51
  3. Продам Вилку DT Swiss XRM 100,конический шток,эксцентрик,новая.
    от андРЕЙтер в разделе Вилки и амортизаторы
    Последнее сообщение: 03.05.2013, 16:09
  4. Продам карбоновую вилку DT Swiss XRC 100 Single Shot 9mm QR 2011
    от _eye_ в разделе Вилки и амортизаторы
    Последнее сообщение: 13.04.2012, 09:01
  5. Куплю новую вилку FOX 100 мм. с поп локом
    от staslife в разделе Вилки и амортизаторы
    Последнее сообщение: 30.04.2011, 14:59
