Выбор велотренажера Direct Drive. - Страница 171
Страница 171 из 690 ПерваяПервая ... 71121141161166169170171172173176181201221271371471671 ... ПоследняяПоследняя
Показано с 1,701 по 1,710 из 6900
  1. #1701
    Я тоже на озоне брал, там в течении двух месяцев вроде можно вернуть товар, пока проблем нет, на счет гарантии не знаю, кто-то в России официально занимается техникой Elite?
  2. #1702
    Цитата Сообщение от humpty Посмотреть сообщение
    Вот по обоим позициям возникают вопросы. И плавающее качество, и "точный" мощемер, который может стабильно завышать или занижать ватт этак на 50.
    Ссылки в студию, пожалуйста.
  3. #1703
    Комментарии к обзору DCR'а: https://www.dcrainmaker.com/2017/09/...th-review.html
    Например:
    "I have been testing my Direto over two different rides now and it seems that I have a +6 % difference (excel comparison on two different files for each ride) on the work intervals between my Stages PM and the Direto Trainer (Direto measuring higher)."
    и
    "Compared with my P2M Type S, it’s about 10% high, always, and I’ve calibrated it several times to be sure. My P2M is consistent generally on RPE vs. my Ultegra Stages on another bike, so I’m thinking the Direto is generous."
    и
    "My direto is 10% high, too. I compared it to a Quarq dzero. I requested it to Elite. But didn’t became an answer."
    и
    "It has been a lot of fun using it on Swift but I have found that the power readings from it are inaccurate. I checked the readings using my PowerTap P1 pedals and found that readings from the Direto were on average higher. I tried re-calibrating the pedals and the Direto. Ride after ride I observed the same difference. I borrowed a friend’s PowerTap wheel to check that my pedals were giving correct power readings and they gave the same readings as the wheel."
    и
    "i did my first ride to day with my new Direto. 11% higher watt readings compared to my PoweTap P1s (dual sided). And I who moved from the Taxc Vortex to get better wattage accuracy…."
    и даже
    "After several workouts on my new Direto I am as sure as I can be that it is reading 50+ watts too low."
    То, что нашлось навскидку. У меня внешнего мощемера нет, даже не сравнить сходу, брешет ли. По многим случая отписывали, что удаленный доступ сотрудникам Элит - и проблема решена.
  4. #1704
    BIANCHI EROS GIANT CADEX 980C (88 г.в.)
    Москва, Мякинино
    Да, у Direto есть проблемы и детские болячки как и у практически любого нового станка, который выходит на рынок. Но тем не менее, как выше было сказано:
    По соотношению цена/качество это лучший тренажер.
    И я купил бы скорее всего именно его, если бы не подвернулся Neo по скидке
  5. #1705
    10% для Элита не погрешность))
  6. #1706
    И? А вот норм ответ на всю эту писанину:
    "Honestly, this looks pretty close to about right. I think you’ve got three things in play here:
    A) Drive train losses: Assume about 2-4% here, depending on how clean your drivetrain is. So on 150w, that’s upwards of 6w or so.
    B) Variants in left/right balance: With a Stages left-only unit, you may have a greater left imbalance (lower), which is what’s causing the gap. It’s exceedingly rare to have perfect 50/50 symmetry, most people have balance differences.
    Unfortunately, without a 3rd power meter to compare against, it’s really hard to know for absolute certain. But the vast majority of people have found the Direto pretty accurate (and most have also found the left leg portion of Stages pretty accurate) – which would lead me to believe that since you calibrated and such, you’re probably looking at a combination of the two factors above."
    К тому же "По многим случая отписывали, что удаленный доступ сотрудникам Элит - и проблема решена".
    У меня тоже нет внешнего мощемера и 2-4% погрешности меня абсолютно не напрягают.
    Скажу так, за 8 месяцев владения и более 2 тыс км. с Direto никаких проблем (тьфу 3 раза).
    Ни к чему не призываю, но ИМХО это лучшее, что есть на рынке за эти деньги.
  7. #1707
    Удалённый доступ для второго случая?
    http://forum.elite-it.com/viewtopic.php?p=2987#p2987
    1) Калибровка трейнера и измерителя мощности. Довольно часто.
    (Иногда, одноногие измерители искажают данные, использование двуногого измерителя мощности может исправить ошибку).
    2) Натяжение ремня. Требуется довольно редко (не входит в нормальные, стандартные операции по обслуживанию, делается по необходимости. Описание исключили из инструкции, чтобы пользователи не ломали тренажёры. Для получения информации нужно связаться с техниками из службы поддержки Элит).
  8. #1708
    Не совсем понимаю смысла ответа. Если Direto завышает, то какой смысл ссылаться на 2-4% погрешности от трансмиссии? А разницей в ногах 10% не объяснишь ну никак.
    Я не ругаю Elite за "плохой" станок. Судя по обзорам - отличный. Лишь опасаюсь плавающего качества изготовления.
    Подписался на ozon, появится в наличии должны оповестить.
  9. #1709
    Трансмиссия - это только 1/3 ответа Рея.
    2-я треть ответа: В случае со одноногими мощемерами 10% это разница между левой ногой х 2 и левая+правая.
    3-я часть ответа: Ну и достоверность это 2 из 3-х, как минимум. То есть, чтобы точно что-то утверждать нужно 2 показания от 3-х одинаковых мощемеров.
    Суда по тесту Рея, Дирето достаточно точен.
  10. #1710
    Я его ответ прочитал несколько раз, там не говорится о 10% разницы между ногами. Народ от силы описывает разницу 47-53, бОльших цифр не встречал. Касательно положительного отзыва DCR'а - по нему и строил свое желание купить.
  4. Поругайте Felt RXC Elite
