Все о DT Swiss ( вилки аморты) - Страница 147
Страница 147 из 280 ПерваяПервая ... 4797117137142145146147148149152157177197247 ... ПоследняяПоследняя
Показано с 1,461 по 1,470 из 3362
Тема: Все о DT Swiss ( вилки аморты)
    Canyon "Metre Per Second"
    МСК, Алтуфьево
    Цитата Сообщение от veloman1977 Посмотреть сообщение
    ПС - ктонибудь перевел чо они там в статьях про него писали? Суть изложите...)
    Копипасть в гугл транслейт
    During our winter riding of the XMM fork we encountered a poor suspension performance at extremely low temperatures with the XMM fork, so they have worked to resolve this by new upper wiper seals and introducing a special oil (called PANOLIN) for lubrication and damping duties. Since the oil is said to improve the overall feel of the fork – we have asked DT-SWISS to do those modifications on our test fork (along with swapping from the remote lock-out lever to the fork mounted one) – but we will report on that in the next update of our fork review.
    Some may remember that during our visit to the DT-SWISS headquarters for the 2013 product launch (here ) we had done two modifications to the fork. One was to exchange the remote lockout lever for a fork mounted one – a thing that can be done without touching the damping circuits of the fork. The other has been to swap the standard lubrication oil for the all new Panolin Specialty Oil, which is said to improve small bump sensitivity and not be prone to low viscosity when ridden in extremely low temperatures – a thing I noted in my first impressions (here) where the fork has been ridden at below 5°F (-15°C).
    Switching the oil over to Panolin definitely caused the fork to perform differently – it got a good amount more active and sensitive, but also big hit performance got enhanced in my opinion – only on steps or small drops would the fork sink into its travel more than before (a thing helped by going for a slightly higher compression damping on such sections). The only side effect of the modification has been that rebound also felt faster, but that was easily taken care of by adding just a few clicks if rebound damping (before I had run the fork´s rebound completely open). Once done I liked the suspension action even better than before – which already has been really good.
    они там пишут что и в демфере масло заменили на панолин... а на какое именно не пишут )
    а еще пишут что старая смазка тормозила только ниже -15гр цельсия... вранье, уже при +5 вилка тормозит )
    Тема разрослась почти до уровня "всё о Fox", а так никто ниразу и не выложил устрашающих фоток потёртых ног, или не подымал проблемы замены башингов и их поисков
    У меня вопрос - тут больше читателей или владельцев?
    они действительно настолько идеальны что не трутся, или у всех пробеги не более 1к?
    у меня всё
    Fight!
    кто они? потертые ноги изза отсутствия смазки или неправильного масла встречались, с башингами проблем не встречал.
    ---------- Добавлено в 23:24 ---------- Предыдущее сообщение было в 23:23 ----------
    Цитата Сообщение от M_P_S Посмотреть сообщение
    когда будешь делать ТО, погоняй поролоновое уплотнение внизу на штоке воздушки
    в смысле погоняй? воздушный поршень без нипеля ходит вроде нормально, поролон там не касается стенок вроде как.
    АААА - все заме6тили что ТО ОРМ требует замены сальников? Вот вам и новые сальники...)
    И еще - на видео DT Swiss/Panolin Factory Fork Oil разделено на 2 банки - в маленькой Лубе флуид, в большой - Fork Oil,
    а продается оно как DT Swiss/Panolin Factory Fork Oil... А теперь внимание вопрос - у них одно и тоже масло в большой и маленькой банках, или разное? )
    Последний раз редактировалось veloman1977; 21.05.2015 в 22:47.
    МСК, Алтуфьево
    Разное, Fork Oil и Lube Fluid. Встретил инфу, что первое 7,5W второе 10W. А так обычные вилочные масла)
    Всё таки решился я поменять ребу на XMM SSII 2014. Нужны гсм, имеется сликхани, а панолина достать негде. Беру суперглисс в штаны/сальники/воздушку или подскажите варианты дешевле/интереснее ?
    Веломаньяк Аватар для Enlyl
    Дружок, Орленок, Десна
    Bike-components к вам не возит?
    BC возит, в основном там и закупаюсь. Не нашёл панолина там, только суперглисс.
    Покупал его у них
    Из переписки
    Hello,
    I'm looking for to buy DT Swiss/Panolin Factory Lube Fluid 100ml
    https://whizz-wheels.de/shop/en/Susp...be-Fluid-100ml
    Could you add this item to your shop?
    Hello Aleksandr,
    we don´t got it listed on our Internet site, but it would be no problem to get it for you as a special order.
    WW-Item-No. 4064XXXXXXXX000026
    Price: 21,95 €
    We can order this article especially for you. So an exchange is not possible.
    Please mention the item number and the price in the comment box when placing the order.
    Best Regards,
    Rainer
    Service
    Hello,
    Could you give price excl VAT for this Item?
    Regards,
    Alexandr
    Hi Alexandr,
    the price excl VAT is 18,45 €. When I should place the order for you, please tell me the wished payment method (Paypal or bank transfer) and the billing- and shipping address.
    If you have any other requests contact us!
    best regards
    Simon
    Service
    Cube AMS 125
    Москва/ Веломастерская Xlab
    о как вес надо экономить, дропауты то пустотелые.
    ---------- Добавлено в 01:51 ---------- Предыдущее сообщение было в 01:49 ----------
    вот жешь, неужели весь заныкали?
    ---------- Добавлено в 01:55 ---------- Предыдущее сообщение было в 01:51 ----------
    Твиншоты со всего мира за несколько месяцев
  1. Обслуживание вилок
    от pustota в разделе FAQ
    Ответов: 27
    Последнее сообщение: 12.11.2011, 01:44
  2. Втулки DT Swiss 240/340, Hope Pro2, DMR; Обод DT Swiss, Mavic.
    от EnteR в разделе Технические вопросы
    Последнее сообщение: 13.01.2010, 00:49
  3. Обслуживание вилок RS в Москве
    от mlg в разделе Технические вопросы
    Последнее сообщение: 20.06.2008, 18:42
