Моя "ж...а" меня "ненавидит". Выбор седла. - Страница 113
Страница 113 из 1008 ПерваяПервая ... 136383103108111112113114115118123143163213313413613 ... ПоследняяПоследняя
Показано с 1,121 по 1,130 из 10076
Тема: Моя "ж...а" меня "ненавидит". Выбор седла.
  1. #1121
    Без 5-ти минут веломаньяк!
    Giant Anthem
    Алма-Ата
    Прошу модератора простить если я не туда пишу, вот что ответили итальянцы
    Our kurve saddles have mobius rails, that are 7x9 mm, as indicated on our website.
    Most part of the seatposts of the market are compatible with our 7x9mm carbon or Mobius rails.
    Basically all those fixing the saddle from the top to the bottom, for example Thompson Masterpiece (2 volts).
    The ones that are not compatible, are basically the ones fixing the saddle from the sides.
    Please open the attached photo
    There is 5 types of seatpost clamps represented:
    Type A: Single Bolt Top-to-Bottom clamp
    Type B: Twin Bolt (Frt/Rear) Top-to-Bottom clamp
    Type C: Twin Bolt (Right/Left) Top-to-Bottom clamp
    Type D: Side-to-Side clamp (single bolt)
    Type E: Hinged Rotational Clamp
    Type A, B & C are typically COMPATIBLE with 7x9mm saddle rails.
    Type D & E are typically NOT compatible with 7x9mm saddle rails
    However:
    For type A, B & C, we do recommend you to test or get confirmation from the seatpost manufacturer that the length of the standard bolt(s) gives sufficient thread engagement when used with 7x9mm rail and that the seatpost still passes all required test/regulations. If it is not the case, longer bolts may need to be used.
    For type D & E, seeing the increase usage of oversized rails in the saddle market in general (either to adapt to new materials such as carbon, or to give additional impact and/or fatigue resistance for specific usage: DH, Freeride, Heavy Weight rider…) manufacturers of this type of seatpost have started to offer optional clamps to fit those different dimensions. Please inquire with your selected seatpost supplier to know if they do offer this option.
    Вообщем муки выбора на ровном месте, к тому же нужна версия с оффсетом
  2. #1122
    Giant Anthem
    Алма-Ата
    Чтобы не офтопить
    http://forum.velomania.ru/showthread.php?t=173526
    Владельцы и люди знающие
  3. #1123
    Цитата Сообщение от Вадим Бегдаев Посмотреть сообщение
    - Я бы напомнил старому, а не попрекал. Хотя бы тупо ссылкой
    Читайте стр.93 данной темы, и будет вам счастье.... (методика определения ширины седла).
  4. #1124
    Цитата Сообщение от Old Nick Посмотреть сообщение
    Читайте стр.93 данной темы...
    - Благодарю, Old Nick. А кто может сказать что будет, если сиденье (по этим предложенным расчётам) для вертикальной посадки, а посадка будет ближе к полусогнутой?
  5. #1125
    а кто что скажет за подобные сёдла? http://www.mtbr.com/cat/controls/sad...16_140crx.aspx
    велотрусы с памперсом имеются
  6. #1126
    отлично все с ним) мое самое удобное седло, но очень ломкое. я 3 штуки сломал за сезон (вешу больше 100).
    Как раз зашел в тему спросить об аналоге этого седла, а тут это сообщение.
    Ребят, а подскажите что-нибудь максимально похожее по ощущениям на Tioga Spyder Twintail?
    Это идеальное для меня седло именно по жопосовместимости, но очень уж ломкое. Я уже 2 треснул, одно погнул. Больше не хочу.
    When all other brakes fail, there's still Hope.
  7. #1127
    а при каких условиях ломаются в Вашем случае?
  8. #1128
    1 раз надавил посильнее (прилетел с небольшого дропа на седло)
    2 раз просто рамки согнулись
    3 раз при падении, растрескалось. от удара.
  9. #1129
    похоже это просто гоночный ахтунг либо для тех кому за 40 и до 60 кг жалко я своими 86 кг тоже наверное прижму его
  10. #1130
    Тему и сайт пролистал основательно, но не нашел. Интересно было бы почитать отзывы о седлах Спешелайзер, в частности Romin и Toupe. Может, есть тут где?
  1. Выбор седла для КК
    от DimaODS в разделе Технические вопросы
    Ответов: 36
    Последнее сообщение: 14.07.2010, 00:33
  2. Выбор седла
    от SeRiK в разделе Технические вопросы
    Последнее сообщение: 01.09.2009, 21:25
  3. Выбор седла
    от Yurex в разделе Технические вопросы
    Ответов: 19
    Последнее сообщение: 09.04.2009, 16:19
  4. Выбор седла!
    от Dень в разделе Технические вопросы
    Последнее сообщение: 18.03.2008, 20:43
  5. Выбор седла
    Ответов: 28
    Последнее сообщение: 19.09.2007, 14:28
