STRAVA
тут с ним не согласны
https://silca.cc/blogs/journal/part-...d-aerodynamics
STRAVA
The Rule of 105%
The rims of this era were all 19-21mm wide, and the Zipp and Hed rims were typically 23mm wide at the widest point, which was optimized for a 19-21mm tire. During the early part of my tenure at Zipp 1999-2013 I noticed in the wind tunnel that any time the tire approached the rim width, the aerodynamics were compromised and from that formulated the rule of thumb we called the Rule of 105(%). The Rule of 105 states that the rim must be at least 105% the width of the tire if you have any chance of re-capturing airflow from the tire and controlling it or smoothing it.
Я правильно понял,что они рекомендуют обод шире покрышек не менее 105%?
Ага.
жаль умалчивают о скоростях обдува.
там не скорость важна, а угол
STRAVA
это ты, дорогой друг, начитался Зипповских проспектов.
прочитай статью сначала. друг.. дорогой..
STRAVA
Нет, не взлетит ((
