Даже вопрос так не стоит - Отдавать сыр или нет...
Из первой ссылки:
I talked to Hope America. They blamed the maxle. Apparently it is more common than I thought. Two different reasons, first the maxle doesn't clamp as well as other thru axles, second they have a smaller diameter than they are supposed too. So I asked if there was anything they could do or know has been done. They said they didn't have a solution. I then asked how they could miss out on such a large share of the market by having mismatching hubs. Should of known what they were going to. Not their fault but RS fault. They also couldn't tell me if it was dangerous to ride with some play in between the axle and the hub.
Интересная история выходит..
И вслед этому:
I have had the same problem with my Hope Pro II front hub and my White Brothers fork. I also have a wheel built with a DT 240 hub and it fits perfectly. I will never buy another Hope product again...
Последний раз редактировалось Павел Бородулин; 22.12.2009 в 20:07.
Да там вообще много всего написано. Как раз поводу твоей цитаты - чувак этот позвонил в Хоуп Америка ещё раз, и ему сказали - да, есть такая проблема, и выслали бесплатно комплект подшипов.
Короче, для меня дело ясное, что дело тёмное, но вариант решения надыбать попробовать можно.
купить ХТ и не париться...
з.ы. и копить на крыс ))
