Последний раз редактировалось pavlinux; 25.04.2018 в 22:16.
Да в целом отлично все, каждый день пользуюсь, периодически с навигацией в горах, где с сигналом сложности, ведет отлично, работает очень долго, датчики цепляет быстро и не теряет, синхронизируется достаточно быстро и стабильно, одно зависание за несколько месяцев не такая большая проблема, впрочем то же и про 935 могу сказать...
New Public Beta* 3.97 Now Available
http://www8.garmin.com/support/downl...s.jsp?id=12819
Changes made from version 3.90 to 3.97:
- Added enhanced support for Varia RTL510 radar tail light.
- Updated touchscreen firmware to 85.11 to improve responsiveness in low temperatures. (сцука вовремя)
- Added CIQ 2.4.4 support.
- Improved device stability.
- Added the ability to discard the current ride at any time. This requires several interactions to avoid accidental discards.
- Fixed text conversion issues.
- Fixed issues with the Varia Vision data screen setup causing the Edge and Varia vision to be out of sync.
- Fixed issue preventing a BLE sensor from being added if it was the first sensor.
- Fixed issue where the ANT generic channel used by CIQ data fields would not reconnect when the device resumes from sleep.
- Fixed issue where battery save mode would turn on GPS in the Indoor activity profile.
- Fixed issue preventing some iPhones from staying connected during the pairing process.
- Fixed issue where the ascent remaining and ascent to next course point data field values did not match the total ascent for the course.
- Fixed several issues with sharp bend warnings.
- Fixed issue where FTP would be reset after recording an activity with a CIQ app.
- Fixed issue preventing battery save mode if the timer is auto-paused.
- Fixed issue where calories would be incorrectly calculated for BLE power meters.
- Fixed navigation audio prompts.
* Напомню, кто любит поработать бета-тестером: есть большой риск, что при установке вся
статистика и настройки на приборе могут сбросится, а не только при откате назад, как пишут гармин.
---------- Добавлено в 22:30 ---------- Предыдущее сообщение было в 21:49 ----------
ConnectIQ Tree Benchmark
- fw: 2.41, score:14285
- fw: 3.60, score: 8928
- fw: 3.97, score: 8198 (минимально измеренная - 7812)
14285/7812 = 1.82, реально стал тормознутее почти в два раза. Тихо скатываемся в го...но.
Последний раз редактировалось pavlinux; 25.04.2018 в 21:55.
На макбуке обновился Garmin Express на 6.4.0.0 и 1030 перестал синхронизироваться хотя и видит его, при этом 935 без проблем.
Скачал с сайте 6.3.0.0 все то же и сам GE обновлений не видит и на 6.4.0.0 не предлагает обновляться...
С айфоном синхронизируется норм.
Похоже, что Garmin идёт по пути "огрызков", искусственно замедляя производительность устройства с каждой новой прошивкой, да бы при выходе новой железки все кинулись менять своё "тормозное старьё".
Те мотивировали заботой о продлении жизни аккумуляторов...
На edge 1000 с прошивкой 14.70 - 8474 попугаев
Последний раз редактировалось Winner; 27.04.2018 в 17:57.
The Winner Takes It All!
