TECHNICAL SPECIFICATIONS
SIZES S/M (17.5”), M (19”), M/L (21”)
COLOUR(S) Gloss White w/ Leaf Green and Charcoal
MAIN FRAME C10 super-light high-modulus carbon w/ internal shift cable routing, shaped oversized ride-tuned down tube, tapered 1 1/8” - 1.5” head tube, PF30 bottom bracket
REAR TRIANGLE C10 super-light high-modulus carbon seatstays w/ shaped ride-tuned chainstay, carbon 142x12mm dropout and replaceable hanger
FORK Manitou Marvel Expert w/ remote lockout, tapered alloy steerer, 15mm thru axle, 100mm travel
CRANKSET Shimano Deore XT, hollow Tech II w/ integrated spindle, 38/24T
BOTTOM BRACKET Shimano sealed cartridge, PF30 adaptor included
FRONT DERAILLEUR Shimano Deore, directmount
REAR DERAILLEUR Shimano Deore XT shadow plus, 10-speed
SHIFTERS Shimano SLX Ispec, Rapid Fire, 20/30-speed
CASSETTE Shimano HG-50, 11-36T, 10-speed
CHAIN KMC X10 w/ MissingLink, 10-speed
WHEELSET Oval Concepts 400 CL disc wheelset, 28h, 15mm front, 142x12mm rear, cartridge bearing hubs, welded rims, stainless spokes
TYRES Schwalbe Rocket Ron, 29” x 2.25” 67tpi, folding
BRAKE SET Shimano Deore, hydraulic disc, 180/160mm rotor
BRAKE LEVERS Shimano Deore, hydraulic disc
HEADSET FSA NO.42, 1 1/8” - 1.5”, sealed cartridge bearings
HANDLEBAR Oval Concepts 250, 6061 alloy, riser, 31.8mm, 9° sweep, +/- 5mm rise, 710mm
wide
STEM Oval Concepts 313, 6061 3D-forged alloy, 31.8mm, 7° rise
TAPE/GRIPS Oval Concepts 600 SLO, dualdensity Kraton, lock-on
SADDLE Oval Concepts 200 w/ steel rails
SEATPOST Oval Concepts 300, 6061 alloy, 31.6, double-bolt micro-adjust
WEIGHT, kg/lbs 11.51kg / 25.38lbs
SLM 29 2.1
