- Fixed an issue causing an extra Activity Profile to be created when syncing Power Zone settings from WKO4.
- Added the ability to set a Ride Type for each activity. This setting will appear in each ride's Activity Type in Garmin Connect. You can set default Ride Types for each activity profile or manually override this with another type when saving an activity. The device will also automatically set the Ride Type to be saved as Indoors when the GPS is off (you can also manually override this on the save/discard page).
- Added support for the following data fields on the Varia Vision: Gear Battery and Gear Combo.
New feature: this release includes the ability to set an activity's
Ride Type.
Garmin Connect will show this setting in each ride's Activity Type. You can modify the default setting for each Activity Profile
and also manually override this value on the save/discard page for each ride. Please note that the following Ride Type settings
are
not yet supported on Garmin Connect, but will be added in the upcoming weeks: Commuting, eBike, and eMountain.
