Compatible with SRAM XX1, X01, X0, X9, X7, S2210, S1400 and Truvativ AKA cranks. GXP and Long spindle BB30 models. Compatible with Boost148 as well. Always use a new chain with a new chainring.
Attention: These spiderless chainrings are designed for Sram GXP and BB30 LONG spindle cranks. This Chainring has an 6 mm offset according to the longer spindle. Long spindle cranks do have 15 mm BB spacer on drive side, where short spindle version has 6 mm. For short spindle version choose the model w/o offset.
То есть если у меня GPX то должен быть оффсет на зведе 6 мм, иными словами звезда будет не плоская. Так? Или есть какие то разные варианты GPX?
