Видел кто? Для эундро хороший вариант.
The result of blending a ZTR Race rim with a ZTR 355, the ZTR Crest is the best of both worlds. All the wall thickness and corresponding durability of a 355 with the next generation BST creating a wider rim cavity with shorter sidewalls. Fully tubeless compatible with the 21mm yellow tape or the 25mm yellow tape and valve stem.
Size 26"x24.4 Color Black Hole # 32 Brakes Disc Weight 340g ISO 559x21 ERD 540 Tape Width 21-25mm
http://www.notubes.com/product_info....roducts_id/492
