[FONT=Book Antiqua]Продам новые колёса под трубку Zipp 303 Firecrest Tubular.
Цвет декалов чёрный. Барабан под Shimano/Sram 10 speed. Эксцентрики + документы в комплекте. Запечатаны. Подойдёт на вес до 113,4 кг.
Цена: 38 000 руб.[/FONT]
Set Weight 1255g
Brake Track Top 25.14mm
Brake Track Bottom 27.57mm
Max recommended rider weight 250 lbs ≈ 113,4 кг
Front Wheel
Weight 565g
Rim Used 285v4FC
Hub Used 88
Rim Depth 45mm
Brake Track Width (center) 26.45mm
Max Width 28.50mm
Spoke Count 18
Spoke Pattern Radial
Spoke Length 258mm
Track Adaptable Yes
Dimpled Surface Yes
Ceramic Bearing After-market
External Nipples Yes
Rear Wheel
Weight 690g
Rim Used 285v4
Hub Used 188
Rim Depth 45mm
Max Width 28.50mm
Nominal Tire Bed Width 17.98mm
Spoke Count 24
Spoke Pattern Non-Drive Cross
Spoke Length Non-Drive 258mm
Spoke Pattern Drive Radial
Spoke Length Drive 246mm
Track Adaptable No
Dimpled Surface Yes
External Nipples yes
Дополнительная информация: http://www.zipp.com/wheels/303-firecrest---tubular/
https://www.bike24.de/1.php?content=...;product=32263
Тел.: +7 916 2627222
Павел
